01-12-2022, 07:11 AM | #1 |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
Rear Shock Removal
Looking to change out rear shocks (with GM lowering kit)It looks like the rear shocks have single threaded shaft on top with a nut. Is the nut accessed from under the car or in the trunk?
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
01-12-2022, 08:12 AM | #2 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
You don't unbolt the top of the shaft to remove them. You take out the 3 bolts that hold the damper top mount to the body that can be seen from outside the car and take it all out as an assembly. From there you can take the top mount off and swap it to the new damper if needed.
2017 SS 1LE.
01-12-2022, 08:26 AM | #3 |
thanks...my main find was to determine if top removal was accessed from trunk or outside/underside of car
01-12-2022, 09:33 PM | #4 |
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
Here's a link to the lowering kit instructions from the Chevy Accessories website.
Not sure if you have MRC as the instructions only covers non-MRC. https://ecom-dam.ext.gm.com/products...s_84408106.pdf |
01-13-2022, 06:54 AM | #5 |
THANKS!
