02-27-2020, 04:58 PM | #1 |
Drives: 2016 Garnet Red 2SS A8 Join Date: Jul 2017
Rear drag radial on 9.5 wheel
Would running a 305/35 drag radial on the stock 9.5 wheel be safe for a few trips to the track when paired with a 275/35 on a 10 wheel? My concern was that the front might be a little wider than the rear
2016 Camaro 2SS - Auto - MRR 017 - Garnet Red
P1X w/ Stage II IC, LT4 Fuel System, JMS Voltage Booster, MMS Catch Can, JRE Off Road Pipes, JRE Tune |
03-12-2020, 08:24 AM | #2 |
You only need to worry about a comparable tire height. Keep the difference less than one inch.
03-12-2020, 08:59 AM | #3 |
Thanks! I know it is less than ideal to not go ahead with a 17” wheel and tire combo but for the few times I would actually make it to the track I was hoping I could safely get by
03-12-2020, 09:07 AM | #4 |
https://www.camaro6.com/forums/showthread.php?t=541363
I never swap tires...been on my car for 4500 miles. The car only sees nice weather...either way it's more then fine for a couple trips to the track. It drives and handles surprisingly well for daily use even at highway speed.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 03-12-2020 at 10:31 AM. |
