07-17-2019, 12:39 AM | #1 |
Drives: 2017 Red Hot ZL1 M6 Join Date: Jan 2017
Rear Side Mirror Tilt Down Time Limitations
Is there a way to have the right side mirror stay tilted down when reversing for longer than... I think about 30 seconds?
Makes no sense that the car decides I'm done with the need for that feature while I'm still squeezing my car into the garage tightly against the right wall while backing in. I have a M6 and usually have to shift to N and then back to R to re-engage the tilt down feature while backing in. Last edited by donaldp; 07-17-2019 at 01:21 AM. |
07-17-2019, 03:53 AM | #2 |
Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
What! I didn't even know it had that feature. Do you activate it by just choosing either of the side mirror side selectors and then go in reverse?
07-17-2019, 04:47 AM | #3 | ||
Drives: Camaro 50th anniversary edition Join Date: May 2017
See Manual page 46 The mirror(s) return to the original position when: . The vehicle is shifted out of R (Reverse), or remains in R (Reverse) for about 30 seconds. . The ignition is turned off. . The vehicle is driven in R (Reverse) above a set speed. Quote:
Select Off, On - Driver and Passenger, On - Driver, or On - Passenger.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
07-17-2019, 11:34 AM | #4 |
Drives: 2018 camaro 2 ss Join Date: Feb 2018
I know that the rear view mirrors focus downward at a predetermine level. You can make them lower manually but that position is not retained. Is there a way to keep the "lower" position that was set manually?
Is so, how would you go about doing that? Thanks in advance |
07-17-2019, 03:06 PM | #5 |
Drives: 2016 Camaro SS M6 Join Date: Oct 2016
I have these at the bottom corner of the side mirrors. No need for tilt. Very helpful when backing into a parking spot next to the curb and getting as close as I can... and into the garage.
https://www.amazon.com/Mr-Zz-Mirrors...%2C180&sr=8-46 |
07-17-2019, 05:03 PM | #6 | |
Seems odd that the car will decide I don't need the tilt down after 30 seconds. |
07-17-2019, 07:36 PM | #7 |
Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
I guess it assumes we drive fast in all directions?
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
07-18-2019, 02:09 PM | #8 |
Drives: 2023 Camaro 2SS 1LE Join Date: Apr 2019
I used to use this, but noticed that it stopped going back all the way to the memory position...really odd but it was annoying that I had to readjust them every time, even holding memory button down wouldn't work, was very weird.
2023/2SS/1LE/Riverside Blue Metallic/M6/PDR/NAV/Red Seat Belts/Sport Alloy Pedals/Wicker Bill Spoiler/Black Sueded Knee Pads/Black Wheel Lug Nuts and Locks/Black Camaro Fender Badge Emblem
1100 - 3/14/23 2000 - 3/14/23 3000 - 3/15/23 TPW 4/10/23 3400 - 4/03/23 TPW 4/10/23 3800 - 4/07/23 4200? - 4/12/23 |
07-29-2019, 08:08 PM | #9 |
18 RS V6 A8 NFG-NPP
Drives: 18' Camaro RS-NGM-V6 A8-NPP Join Date: Apr 2019
Not all trim packages have the reverse tilting mirrors. On pg47 of the manual it says you need the memory seat option to have the reverse tilting mirrors.
18 RS-V6 A8-NGM-NPP-SILVER RALLY STRIPES-BLK BOWTIES-BLADE SPOILER
07-30-2019, 02:22 PM | #10 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
I think this feature is only available for models with the convenience and lighting package. If you want to check if you have it..look under comfort and convenience option in the radio. It can be found under vehicle.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
