Old 09-30-2018, 02:56 PM   #1
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
One more event? Tread???
For those who have more experience, believe these have one more event before replacement... Car has track alignment. Note, front only shown, back in better condition.
Thoughts?
Thx Tim
Timbo-1LE is offline   Reply With Quote
Old 09-30-2018, 05:56 PM   #2
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Yes definitely one more, if not even another before cording IMO. Clearly needs keeping a close eye after each individual session though.
driven2exceSS is offline   Reply With Quote
Old 09-30-2018, 10:49 PM   #3
HYPER1LE
HYPER1LE's Avatar
Drives: 2017 Chevrolet Camaro SS 1LE HBM
I agree. When mine looked like that, I just wrapped up 2 more track days out of them. Now, they’re done.
HYPER1LE is offline   Reply With Quote
Old 10-01-2018, 01:16 AM   #4
hzycamaro
hzycamaro's Avatar
IMO if you are not sure, just take 2 new front tires with you (if there is tire shop on track or nearby). Once I was in the same situation and the tires were cording after only one session. Basically wasted a day's time and money
hzycamaro is offline   Reply With Quote
Old 10-01-2018, 08:25 AM   #5
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Outside edge has at least 3 days left, can't really tell how bad the inside edge is from the pic, but I'd be more worried about the inside edge if you have the track alignment.
Old 10-02-2018, 01:47 AM   #6
TrackClub
TrackClub's Avatar
Now these are well used tires: congrats lol!
OP: your tires have tons of life left. But as suggested check the inside edge as well. Edit: the above is a good pic of corded rubber if you've never see one before. Obviously it is not recommended to drive on corded tires, but some have All it means is the rubber is gone. Of course things can start tearing and separating as well at that stage depending on circumstances.
Old 10-02-2018, 06:34 AM   #7
TheRealJA105
Drives: 2013 C6Z06
Thanks! I'm proud to wear out the fronts before the rears on a high horsepower RWD car. I don't think the tire people could wrap their heads around that haha. I kept only looking at the outside edge and it was a good thing i checked the inside edge before the last session that day. I tried to get my toe zeroed out as much as the alignment tech was willing to play around with it for my new set. We will see if that helps on the inside wear which i assume was coming more from street miles. I'm also going to start running higher pressures on the street instead of only around 30 cold.
Old 10-02-2018, 09:16 AM   #8
TrackClub
TrackClub's Avatar
Ive noticed good deal of wear on the inside shoulder from track use on inside front tire (RF on CW tracks for example). I havent noticed any excessive wear from street driving albeit i dont use my car as a daily much. But some of my track trips are pretty long distances. Thats with 2.6 camber and a very slight toe out.
I use 32 psi for street (as recommended by GM).
Old 10-02-2018, 06:32 PM   #9
driven2exceSS
Yeah good idea, I've been running 34 cold for the "little" street miles it gets, mostly to and from "local" tracks (60-110 miles each way). And, they are wearing quite even. Although I just went to 35 to save the very last bit on this set. lol Either way the street pressures will be even less of an issue in my case, the trailer is due in tomorrow! I mean it's only been two years in the making
Old 10-03-2018, 03:45 AM   #10
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Drivers side
Here is the drivers side, inside at bottom of pic, which has the most wear. Based on above, sounds like I'm good for one more event. It is Daytona, so as your aware some parts of the track are not friendly if you have an issue....
Old 10-03-2018, 08:19 AM   #11
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
I run my tires until they look like this normally, I pulled these off after last sunday's event in fear they were going to let me down in a bad way.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 10-03-2018, 09:04 AM   #12
TheRealJA105
Drives: 2013 C6Z06
Damn, i wish i could get my tires to wear that evenly.
Old 10-03-2018, 10:52 AM   #13
ICTsccaCamaro
ITCRNRS
Its all about camber and flip mounting the tires before you cord the shoulder.
Old 10-03-2018, 12:20 PM   #14
TheRealJA105
Drives: 2013 C6Z06
I think the ZL1 1LE suspension eliminating the dynamic camber change is the key to your wear vs mine.
