06-16-2018, 05:03 PM | #1 |
Drives: 2017 SS 1LE Join Date: Mar 2017
Remove engine covers? LT1
Any who tracks their car remove all the plastic covers and sound deading? Assume all that just holds heat in...
06-16-2018, 05:18 PM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
I’m sure it’s worth some cooling, but I have never heard of temps being an issue for the 1LE.
I Track at Sebring and Daytona (in June/July/August) and haven’t had any overheating.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
06-16-2018, 05:36 PM | #3 |
Agree. Same here, same tracks and no issues. Just wondering if would help, and less stress, etc on engine and intake temps... Things you ponder on a Saturday in Florida
06-16-2018, 05:37 PM | #4 |
Btw. Who do you go with for Daytona? PDG has pulled out due to cost..
06-19-2018, 10:02 AM | #5 |
I removed all my covers, I think they do hold heat in the engine. There is a foam insulator on the intake manifold as well as the plastic covers that will prevent some of the heat from dissipating from the engine. I have not heard of anyone having any over heating issues. I think it will cut down on the under hood temps along with a better heat extractor in the hood. You can take drain cups off the hood extractor and get more airflow out of the engine compartment (they snap in/out). The engine compartment looks better with the covers but I prefer to get as much heat out of my engine compartment as possible for longevity and power. I opted for carbon fiber hood with corvette style heat extractors. The engine is definitely a bit noisier without the covers but that doesn't bother me.
06-19-2018, 07:41 PM | #6 |
Thanks for posting. May give it a try
06-19-2018, 08:51 PM | #7 |
I took mine off some time ago, I mostly run mine on drag strip or street. It does unleash some sounds the DI engines make that you may not be use to hearing as well as cause extra heat on your intake. The intake cover had a felt/plastic liner under it that helps keep your under hood heat from soaking into your intake plenum. When I took this cover off my car my intake temps went up 8-12 degrees, but my ability to cool the intake between pulls was much more effective. Mostly because I could set my bags on the intake directly. On the street though, it caused my intake temps to creep up just a little and made the engine sounds a little louder. Not the nice exhaust note either lol.
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons Custom cut Brian Tooley Cam SW long tube headers 3" stainless mid pipe - Secondary Cat delete - High flow cats Port and polished heads-Double valve springs-platinum lifters & push rods Cam phaser limiter - DOD delete P1SC-1 Pro Charger 3.7 pulley Stage II intercooler 667rwhp 577ft lbs |
06-20-2018, 11:04 PM | #8 |
Then maybe not so good for a road course 1LE then. Thx, data helps...
06-21-2018, 06:30 AM | #9 |
Chevy71 thanks for the info, you have a pro charger which makes a lot of heat but your information is great data. I will putting the insulated cover back on my intake!
06-21-2018, 07:17 AM | #10 | |
I also have a stock hood with the two small vents for letting that under the hood heat out. If I had a better hood to flow more air it may not be as big of a deal too.
06-21-2018, 08:19 AM | #11 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
06-21-2018, 05:29 PM | #12 | |
SCCA runs it 2-3x's per year. http://www.cfrpdx.com/
2017 HBM SS 1LE
06-21-2018, 06:56 PM | #13 |
I watch it on my nGauge. Where my car typically runs and where it runs with the covers off. I put them back on from time to time when I'm not going to the track or trying to cool the intake quickly.
06-22-2018, 07:09 AM | #14 | |
I’m just curious because I’m going to data log this next time at the track on a NA/factory engine. The intake is in a totally different place on a Procharged setup (next to and above the engine). |
