07-08-2018, 01:47 PM | #1 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Magnetic shocks - How good are they??
What I mean by this is in terms of rear-end chassis control.
Or I guess put another way is rebound control. Say you are in a high speed sweeper at 110MPH with the suspension loaded up and there is a dip in the middle of the turn. Is the initial rebound from that dip neutralized immediately? I had magnetic dampers on my old Audi TTRS a few years back and they were amazing on that car when driven in anger, you could not upset that chassis no matter what you did. It was truly as good as a coil-over suspension in that regard. However that car was a lot lighter than the SS 1LE. Is the SS 1LE that solid when driven hard, do the magnetic dampers do that great of a job with body/chassis composure? As good as a coil-over would. Again, I am just talking about composure here, obviously having a coil-over has other advantages. |
07-08-2018, 02:39 PM | #2 |
Drives: 2SS 1LE Join Date: Oct 2011
Chassis stability does not just come from increasing low-speed rebound damping (shaft speed, not car's speed), it also comes from increasing low-speed compression, so I'd want the accelerometers to register that the car was in a g-out situation and instantly increase the compression damping. This would likely have the biggest effect actually at resisting that kind of movement.
As far as these dampers, well, GM has been a pioneer here and the chassis is very hard to upset at speed. I wouldn't say the feel is the same as coil-overs, but the different settings are dramatically different. I rarely, if ever, go to the "tour" setting, just because I feel there isn't enough damping to control the chassis movement. It makes it softer, but with the car bobbing and dipping more it kind of negates the setting IMO. I think it increases the chances of bottom-out too. So I'm mostly sport and that's nice and firm, but not too firm except for rare occasions.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
07-08-2018, 03:54 PM | #3 | |
I'm just curious, as you know if you have read my other threads here or on Bimmerpost, I moved to Ohlin R/T coil-overs on the M3 because the stock damping was horrible. The Ohlins are both good and bad. The are a little harsh over big bumps and will actually cause the traction control to activate on some big bumps and it will lift you out of your seat, however the faster you go, the better they get. 110-120ish feels SOOOOO stable and composed. Was just wondering if the Magnetic dampers are that good at the high speed stuff, but without the harshness of a coilover. In the case of the Magnetic dampers I had in the Audi TTRS , the answer was a solid YES. Hoping the same is the case for them on the 1LE. BTW, I should be flying down to the LA area next weekend and driving back home in my new 1LE. |
07-08-2018, 05:36 PM | #4 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
I used to own an Audi TT (Gen.1 / 8N) and had a Koni FSD -Eibach springs setup which I liked a lot. Perfect (to me) for both DD Street and Autocross. Had the TT in my possession for almost 15 years so it means something she also had about the same WHP as my 1LE today and was indeed by at least 1100 Lbs lighter - so you can probably imagine the far better Power/Weight. However, in terms of handling, steering response and feeling "planted", the 1LE is by far superior (despite the TT was on sticky Toyo 888Rs). The 1LE feels larger (but not that much... surprisingly). It would be interesting though, to see how the 1LE would handle on the same Power/Weight ratio as the TT. This would mean upgrading to an FI motor in the range of 600 WHP and then comparing. |
07-09-2018, 12:09 AM | #5 |
Drives: 2018 SS 1LE Join Date: Mar 2018
Third generation magnetic shocks are as good as it gets for a dual use street/track car.
https://www.google.com/amp/gmauthori...echnology/amp/ |
07-09-2018, 06:38 AM | #6 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
OP: congrats on the purchase!
I dont drive my 1le in anger, but i do track it, incl at Mosport, which is one of the fastest (if not the fastest still?) road circuits in NA. The venue has many fast sweepers with big elevation changes and compression zones including going from the fastest corner (T4) to the slowest (T5a) at about 120. Zero issues. No bottoming out ever. Excellent composure even going over a bump at the end of the back straight at 145. Another example would be the Glen, where my C5Z with LG race coilovers had a tendency to slightly step out in the esses...1LE however is superbly planted there. Go to official track vids/photos thread and watch Provoste do a 2:10 at the Glen on street tires and then an absolutely ridiculous 2:04 on Pirelli scrubs. This is a stock car save for an alignment. Obviously Provoste knows how to wheel a car, but the recorded pace speaks volumes as to the stock suspension capabilities. Even with slicks on. Amen |
07-16-2018, 01:15 PM | #7 |
UPDATE: I got my car on Saturday and have driven it 500 miles so far (including the 300 miles home from So. Cal, and my concerns are gone COMPLETELY gone.
F*ck, this car is solid and has super high limits. I was seeing 1.2G's on a few on/off ramps. Now, my only issue (and this may be due to the new tires) , but I can feel a little flex in the rear. Now, my M3's rear-end was bolted directly to the subframe, and since this car has rear bushing, I am not sure if that is what I am feeling. The rear takes just a split sec. to set, and then it is solid. I am already thinking about the BMR rear cradle lockout kit as well as their upper and lower control arms. I want to see if it is coming from the new tires though first before I do anything. Also, Dry mode is perfect for learning the car. I do wish the throttle was more direct. It has good tip in, but then there is a dead spot in the middle and then when you get deeper into it, it comes alive again.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
07-16-2018, 01:35 PM | #8 |
Drives: 2SS, CT-R, LC500 Join Date: Jan 2018
Yeah. I rented a 1SS twice. Drove the twisties along pacific coast highway 1 PCH1. What a car! I got a 2SS specifically for the MRC. Its good, just dont expect a Lexus ride.
07-18-2018, 10:35 AM | #9 | |
Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
07-18-2018, 10:39 AM | #10 | |
07-18-2018, 10:42 AM | #11 |
Coilovers would definitely make the car faster around a track but you loose the streetability when you switch to them. DSC is about to come out with an MRC coilover kit and it's gonna be phenominal. Robert Weathers has been working the bugs out and it will soon be available from JDP Motorsports. The only thing is it won't be cheap. Lol
07-18-2018, 10:55 AM | #12 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
07-18-2018, 01:29 PM | #13 |
Do you remember at least the ballpark price of these shocks?
07-18-2018, 01:54 PM | #14 |
Sure, why not?
Sorry, but I really can't.
Hang on. *goes and searches on google* Here: https://www.gmpartsonline.net/auto-p...omponents-scat A front magnetic damper is $367.25. Not exactly dirt cheap, but they do perform well. By contrast a similar electronic shock for my BMW motorcycle is $1754.78.
