01-04-2020, 05:55 PM | #1 |
Drives: 17 Camaro SS Join Date: Nov 2019
Soler Throttle Body
I was reading all the instruction on starting and getting the ecu to learn the TB. I have an i3 so I'm planning on going in and adding fuel to compensate for the extra air and skipping all the running cycles. Any thoughts??
01-04-2020, 06:32 PM | #2 |
Drives: 2015 Corvette Stingray Join Date: May 2019
Hi, DannyC. Yes, you can do that, no problem. Even after you tune there will be some learning as it will apply small refinements with fuel trims, but you can let that happen as you drive normally. Do the battery disconnect, and the idle learn at least (idle 3 min, off 1 min, idle 3 min, off 1 min).
01-04-2020, 07:19 PM | #3 |
Ok thanks Mike. I thought there would be some others here that been through the process.
By the way I sent you an email pretty much saying what I said here about using my tuner. |
01-05-2020, 01:47 PM | #4 |
Got the Soler ported TB installed Yeah!
Everything worked pretty well, removed the stupid sound tube(wtf), install went as expected but took a little longer than I expected, about 35-40 minutes which isn't bad. It took awhile to get the air duct back on lol. First start the ECU went crazy. Traction on and off, tach dropping to zero then right back up, most of the gauges were doing that. Turned it off and back on a few times and it settled down a bit. It did throw 2 codes, one was transmission and can't remember the other. After several restarts, I reset the codes with my tuner and took it for a drive. I didn't beat on it since I haven't finished installing my A/F wide band yet. That should be done this week. And by the way the Diablo i3 only allows you to add fuel at WOT so my adding some fuel before first start didn't really help.
Flow Tech axle back, Roto-Fab, Nick Williams 103, AEM Wide Band, Defrost vent pod, billet catch can, BBK long tube headers and NGK LTR6GP, #90198, one step colder, Magnuson 2650, Snow Performance water/methanol injection. (Also tune myself w/HPTuners)
01-05-2020, 07:32 PM | #5 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
01-08-2020, 01:12 PM | #6 |
Ok final update on the TB install. I finally got my wide band installed and wanted to make sure I wasn't running too lean at WOT.
I had initially added 2% at 1-3000, 1% 3-5000, 1% 5-7000 @WOT. All rpm were 12+ which is good but maybe a shade rich. after 5500 it got even richer so I went back in and pulled the 1% I added up top so it was back to the original Diablo 93 octane tune. I'm going to drive it a few days to see if anything changes then do some data logging to fine tune the A/F and timing settings Over all I think the Soler TB is a great upgrade! Runs better and even sounds different.
01-08-2020, 05:56 PM | #7 |
Drives: 2017 Camaro 2SS Join Date: Mar 2019
I just did the Soler LT5 upgrade from the LT1 I originally bought from Soler, and like you felt an immediate and positive difference. Getting that CAI duct on that bigger mouth was a b**** though!
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon |
01-08-2020, 06:05 PM | #8 |
I had the same issue with the Roto-Fab. The connector was big enough but the thing was already touching the fan shroud and the 1/2 spacer made it worse. I finally had to shove the coupler at the air box end all the way onto the air tube, and putting the coupler onto the TB, tighten it then put the tube into in and forcing the tube down until it aligned with air box.
01-08-2020, 06:23 PM | #9 | |
I had a heck of a time getting the duct over the mouth, but finally some tube lube facilitated it!
Gary
01-08-2020, 06:48 PM | #10 |
The Roto-Fab has bigger tube and coupler. It was a loose fit on the stock TB.
Thread Tools | |
