05-13-2019, 03:17 PM | #1 | |
Drives: 23 2SS 1LE Join Date: Feb 2019
Dash cam not working?
You may have seen me post here before about my dash camera. So right now I have 2 separate ways to power it, the original being the OBD sensor but I wanted to wire it to the fuse box instead. So now, my second way, I have the wires running down the passenger side, into the hood, and wired as you see here.
The problem is, its not getting power. When I switch to the other cable, the dash cam turns on no problem. I switch to this one, and get nothing. I have 2 wires, the power and ground, as you can see the ground is going where the other vehicle ground is as seen in this video starting around 15:00: And my other wire is going to the 15 amp fuse, also shown in that video which is supposed to be the accessory tap. I have also tried on the 30 amp fuse that was always hot, and neither time did I get any power to my dash cam. Am I doing something wrong? Or is something broken?
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
05-13-2019, 03:43 PM | #2 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
I'm going to go with bad crimp on your fuse connector wire splice. did you check for continuity with your wire before plugging anything in ? Assuming you're connecting to a fuse that is otherwise getting power to begin with.
Or blown inline fuse in that splice. But I assume you checked for blown fuses. |
05-13-2019, 04:32 PM | #3 | |
All fuses were checked and are all good. I will go and fully crimp it and test again. EDIT* I do believe the fuse I am tapping into is the horn. according to this anyway: https://fuse-box.info/chevrolet/chev...ses-and-relays
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 Last edited by RideWithDanger; 05-13-2019 at 05:12 PM. |
05-13-2019, 05:58 PM | #4 |
I tapped into F22 which I believe is the "Antilock brake system valve" and now the camera will run 24/7 until it detects the battery is too low.
