01-31-2019, 04:29 PM | #15 | |
Drives: ZL1 1LE SUMMIT WHITE Join Date: Feb 2018
Sweet! Thanks!
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________ 2005 NISSAN TITAN 1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18 2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD |
01-31-2019, 05:27 PM | #16 |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
01-31-2019, 06:07 PM | #17 |
Drives: 2019 LT3 RS Convertible Join Date: Sep 2018
USB 2.0 can provide about .5 amp (500ma) at 5v. 3.5" spinning hard drives take too much power to spin up and usually require external power. 2.5" drives will mostly work as they take less power. The larger in capacity the 2.5" drive, the less likely it will be able to be run on 500ma given the heavier platters and additional heads. SSD takes FAR less power and would also work fine at any size but get unreasonably expensive over 500GB for this application.
I would think a 1TB 2.5" spinning drive would run fine. The only remaining question is if there is an addressable limit. That depends on the code of the system and partition format. Most mobile media like thumb drives and external drives are formatted FAT32 which has a partition limit of 2TB. I suspect the system runs on linux (at least I hope it does) so it might recognize ext3/4 partitions which can be much larger. NTFS is likely not going to work as it is a Microsoft format. I don't have my car yet so I'm making assumptions about the system. It may have usb3 which is good to 900ma. Your manual may say more about the supported formats. |
02-01-2019, 12:15 PM | #18 | |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
05-14-2019, 11:56 AM | #19 |
Well the HD works just fine in my car however the display regularly shows in the "Artist" field *Unknown*.
What fields in the individual file properties (Windows 10 File Explorer) need to be filled in to work with the Chevy System?
05-14-2019, 01:53 PM | #20 |
Never mind the above. Did a little exploring with the system and found the "Folder View" option.
All is good in the tunes department now.
05-14-2019, 02:08 PM | #21 | ||
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
Exfat also doesn't have the file size restrictions that FAT32 does. There is also a GPL for Linux so it does work within that operating system as well. Ultimately, I would say buy a 256GB or something similar in size flash drive, as it will more than accommodate your music selection. They're generally pretty cheap, take up very little space, and least likely to be stolen from your car as you dont have to worry about it being hidden. Mine is so small you wouldnt even notice if you didn't actually look for it. I speak from experience, as I have well over 400 GB of music myself.. Quote:
The metadata tag (which is the info in the track that tells you what song/artist/album/etc) is often missing in ripped music that's downloaded from online. It's also usually modified to advertise places you got it from (if you didn't buy it). You can use applications like this one to modify the data: https://www.mp3tag.de/en/ You can also view it to confirm the data is even correct or present.
05-14-2019, 02:09 PM | #22 |
Nightmare
Was replying when you posted....but that is also a possibility too Congrats on finding out it was something very simple.
