12-07-2018, 09:10 PM | #1 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Skip Shift Eliminator Reverse Lockout
Just a PSA to everyone, I installed a skip shift eliminator a few weeks ago from a VERY reputable manufacturer. Had one on my 4th Gen, worked just fine. After I installed this one I noticed going into reverse was REAL hard. Googled around and ran into a 5th Gen thread where a guy was having a similar problem and a seasoned GM wrench told him it was his skip shift eliminator. Figuring it’s free to give that a whirl, I pulled mine off today and of course she slides into reverse perfectly now...go figure.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
12-07-2018, 09:45 PM | #2 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
I have the phastek one and no problems here.
You may have installed the product in the reverse lockout solenoid instead. They look exactly the same. I saw the mistake made on Camaro5 several times. |
12-08-2018, 04:58 AM | #3 |
Drives: 2017 ZL1 6MT Join Date: Feb 2018
No issues whatsoever with mine and I installed it myself. BTW, the installation was a PITA...especially if you have large hands.
2017 ZL1 Arctic Blue Metallic / 6MT / sunroof / NAV / PDR / RotoFab CAI + dry filter / Tony Mamo TB V1 / Skip Shift Eliminator / Hurst Short Throw Shifter / ZL1 floor mats / Dead Pedal cover (to match other pedals) / ARH Catless 1-7/8" headers + ARH X-pipe + AWE Touring Axle-Back / Diode Dynamic smoked side markers / American Authority tow hook
12-08-2018, 05:21 AM | #4 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Sounds like you installed it on the reverse lockout solenoid and not the skip shift, the plugs are identical. The skip shift is on the driver's side on top of the transmission and the reverse lockout is farther back. If it was easy to install you got the wrong one, use a long skinny screwdriver to unlock the tab.
12-08-2018, 02:06 PM | #5 |
Hmmmmm. I'll check it out!
12-08-2018, 09:48 PM | #6 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
LOL yea you installed it on the wrong one. You put it on the reverse lockout and not the 2nd gear lockout (which you need like a 14 inch flathead to reach above the transmission) i did the same
12-08-2018, 11:28 PM | #7 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Got mine from Summit Racing. Works perfectly and reverse is no issue at all.
But, like Agent K said, it was a real PITA to install with big hands and thick arms. Had to use some long pliers.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
12-08-2018, 11:55 PM | #8 | |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
12-09-2018, 08:23 AM | #9 |
Drives: 17 krypton green 1le Join Date: Feb 2017
As others have said it’s probably on wrong plug. I know because I did the same thing even though it was on my lift. Went to move the car a few days after the fact and no reverse! After I had my oh !?%^* moment where I thought my car with probably 150 miles at the time had tranny problems I realized what I had done. Felt pretty dumb for sure. I’ve had them on a couple t5-6 cars in the last but this seemed pretty tough to get to in Comparison.
12-09-2018, 09:07 AM | #10 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
The skip shift solenoid and harness are shown here: https://www.camaro6.com/forums/showthread.php?t=461240
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
12-09-2018, 01:01 PM | #11 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Not related to the question but...
I have had the skip shift feature on my C5 and C6 Z06 and it worked as designed and just dealt with it, but in my SS 1LE, no matter how mellow I drive and even when I shift with the little message on the dash saying it will activate, it never has once since I had the car. I am at 6,500 miles now and not once has it tried to put me in 4th from 1st. I was thinking maybe the skip shift eliminator was installed before I bought the car from maybe someone who maybe took delivery but couldn't get financed and had to turn it back in, but my car had 6 miles on it when I picked it up, so I doubt that could be it. Not that I am complaining, just strikes me as odd that I have never once tripped it even when I was in the parameters to do so and with the messaging saying it would. The things that make you go hmmmm.......
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
12-09-2018, 04:36 PM | #12 | |
12-09-2018, 04:56 PM | #13 | |
Current:
