10-19-2021, 09:33 PM | #15 |
Drives: 2010 Camaro SS Join Date: Oct 2020
Are you getting any DTCs after the Stabilitrak message? When you get the Stabilitrak message it typically means the car is putting it self in "Safe/Limp Mode" to prevent damage due to a critical sensor failing or threshold being exceeded. If the actuator was triggering the "Safe Mode" it should be throwing a P21xx DTC prior to the Stabilitrak message. In my case I started out getting a P0016 which led me to tear half the motor apart chasing machanical failure. When the code came back after replacing about $400 worth of good parts I started digging deeper into the Stabilitrak issue rather than the P0016. The thing that ultimately led me to the core of my issue was a U2100 DTC which I was overlooking. This code is triggered when you get a poor reading due to a short or open circuit. If you don't have a good ODB scann tool that will show EBCM or "U" faults I would take it to the dealer next time and have the issue and have them run a full scan for you. It should not cost more that $50 if they charge you at all. It is sounding more and more electrical/sensor related issue in my amateur openion. Good Luck!
Sent from my SM-F916U using Tapatalk |
10-19-2021, 09:54 PM | #16 |
Drives: 2011 Camaro SS/RS M6 Join Date: Oct 2010
I'm not getting any codes at all. I do have an OBDII scanner. It sees nothing.
10-19-2021, 09:56 PM | #17 | |
All pulling these fuses will do is clear the PROM in the ECU which is essentially clearing all the stored data in the ECU fuel tables, shift learning, DTC data, etc.... It probably cleared the stored DTC data which is why it fixed the issue temporarily until the thresholds were met again.... Sent from my SM-F916U using Tapatalk |
10-19-2021, 09:59 PM | #18 | |
10-20-2021, 07:40 AM | #19 |
What ODB2 do you have? Some of them don't read all the codes. The U codes you need an actual diagnostics scanner not just a reader.
10-25-2021, 06:47 PM | #20 |
Well, I'm still having issues. I swapped the throttle body, did the relearn process, nothing. Decided to reflash my tune, still having erratic idle. I was able to bump up the idle 100 RPM & it hasn't stalled, but that's a bandaid. The engine seems to be running fine otherwise.
11-03-2021, 01:54 PM | #21 |
Well, I'm still having issues. I swapped back to the original throttle body because the replacement was not behaving properly. It was on deceleration in neutral the idle was going up between 1500-2000 rpm. Still occasionally getting the service stabilitrak after stalling at idle or driving down the road. I'm running out of ideas.
11-08-2021, 07:14 PM | #22 |
Brake issue
I was driving my car today,and a brake system warning light came up on my center gauge,then pops up my ABS warning light and TCS warning light came on all at the same time,so,what’s going on,thanks.
11-09-2021, 09:00 AM | #23 |
Check your battery, sometimes when they start to go bad they light up the dash like a Christmas tree like that..
11-10-2021, 12:26 PM | #24 |
Drives: 2013 1SS Join Date: Dec 2012
For me it was the wheel speed sensor. I don't recall the code but I was able to read it once using my SCT and then never again. The dealership told me which corner and I did the rest.
12-27-2021, 03:08 PM | #25 |
Well, I've continued to get the service stabilitrak messages for the past few weeks. I did start getting a P0335 & P0336 error codes. Up until this point, I didn't have any codes. So, I swapped out the crank position sensor and so far no error messages. I'll have to see how it goes the next few days. I hope this is the only problem.
08-07-2023, 09:04 AM | #26 | |
Drives: 2012 Camaro LT2 LFX Join Date: Mar 2023
