Roto-Fab
Old 11-04-2019, 04:10 PM   #1
km9v
Drives: 2011 Camaro SS/RS M6
Question Best budget axle back?
I've got a Dynomax currently installed. There's now a rattle in one of them I guess something broke inside. Budget is a little tight. Mid pipes are removed, stock manifolds & cats. Muffler delete is probably a little too loud for the neighborhood.
km9v is offline   Reply With Quote
Old 11-05-2019, 10:04 PM   #2
dino2012ls3
Drives: 2012 ls3
If you have stock manifolds and cats, the muffler deletes are not that loud. I actually thought when I did that it sounded like a sports car. Now I have LTs and no cats and it freaking loud!!!
dino2012ls3 is offline   Reply With Quote
Old 11-06-2019, 08:41 AM   #3
km9v
If the mid pipe resonators weren't removed, I'd agree with you. But I cut mine out when I got the Dynomax set b/c it was too quite. Maybe I could remove them & try it out to see if it's tolerable.
Old 11-06-2019, 10:02 AM   #4
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Go browse our member classifieds.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 11-07-2019, 12:36 AM   #5
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Budget axleback?
Legato. Very high quality and sounds great. That was my first axleback for this car. It is a chambered muffler and sounds similar to the Flowmaster American Thunder, very similar muffler design. Brand new $169 (2010 - 2013) and $309.99 for (2014-2015). Not sure why...I think maybe the hanger placement is different?
I paid $299 for mine a few years ago, so the price came down bigtime. But for $169 for your model year for a complete axle back setup, including polished double wall tips, clamps, and lifetime warranty? You cannot beat it. I loved mine, just wanted to go a bit louder at the time. I may put them back on again.
https://legatoperformance.com/
InFiD3ViL is offline   Reply With Quote
Old 11-07-2019, 07:09 AM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
For the price of most axle back exhausts, why not get a 3" catback from Speed Engineering?
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 11-07-2019, 02:00 PM   #7
km9v
Originally Posted by InFiD3ViL View Post
Budget axleback?
That's not a bad price. I actually called Dynomax & my axle back kit is covered under the lifetime warranty. So, all I have to do if find the receipt & email it to them and they're going to send me a whole new kit.
Old 11-07-2019, 02:15 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Well you cannot beat that! Glad to hear they will take care of you.
Old 05-12-2020, 07:47 PM   #9
Cheap Guy
Cheap Guy's Avatar
Based on the comments in this thread I figured I’d try the Legato axle back, especially at $150 shipped. I was contemplating just a straight pipe based on some opinions but I just didn’t like the idea of basically going muffler-less. Also, I just hated the way the stock mufflers look so even if the sound was exactly the same, it was worth it for appearance sake.
Install was straight forward, except definitely just cut at 7” back from the hanger instead of the 9”. It does warn you to check before you cut. It’s kind of cramped under there so be careful you don’t hit the control arm, differential or axle. Use a new, short metal blade and it cuts right through the stock pipe. Cut one side at a time and test fit before you cut the other. Make sure the clamp doesn’t block the diff drain plugs.
After I cut both sides and test fitted I wanted to see how it sounded with no mufflers. Maybe it just because I’m older but to me it sounded loud and crappy. I’m glad I didn’t go the straight pipe route. The Legatos have a nice, slightly louder than stock sound with a nice rumble. Directly behind the car you can definitely hear the difference but inside with the windows up not so much.
No telling how long these will hold up but I don’t put a lot of miles on this car, especially in rain or snow. The quality seems decent and the fit was fine. If you’re on a budget these aren’t bad at all.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold
Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current
Cheap Guy is offline   Reply With Quote
Old 05-12-2020, 11:55 PM   #10
InFiD3ViL
InFiD3ViL's Avatar
I'm glad you like them. They really surprised me with the quality, especially for the price point - I was also surprised at how much care was taken with their packaging compared to other brands I have owned. If you ever decide to go with long tubes they really sound amazing and get much louder, but still go a good job keeping the tone clean.
Old 08-03-2020, 04:35 PM   #11
Cheap Guy
Cheap Guy's Avatar
After a couple of months with the Legato axlebacks, looks like I’m going to take them off. They look great and sound great in lower gears, actually a bit loud for my old ears, but I learned about the term “drone” which occurs right about 2000 rpm in sixth gear. Might not bother some people but it’s irritating as hell to me.
I might try the Borla touring once I get a few bucks. I hate the look of the stock suitcases but I may have to just put them back on.
Old 08-04-2020, 10:15 AM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Had this as my first axle back on my 2011 SS. The drone wasn't bad at all.
https://pypesexhaust.com/i-13475216-...omb-sgf53.html
1JEWLDSSRS is offline   Reply With Quote
Old 08-04-2020, 03:31 PM   #13
InFiD3ViL
InFiD3ViL's Avatar
Yea it wasn't bad for me either, definitely much better than my FM Outlaws in that regard. I still have mine but removed them for being 'too quiet'.
I reinstalled them after my cam install but it was still too quiet for my tastes. They stayed on overnight and put the Outlaws back on the next day. They do sound very good though. This will likely sound stupid, but they (Legatos) change the way the car feels to me at lower rpms. Almost a feels little torquier, but likely it's in my head.
Old 08-04-2020, 05:29 PM   #14
Nailedit187
Drives: Chevrolet Camaro
I was in a similar boat last year. I went with rev9 mufflers. I had LTs and straight piped. it was a little much. Car now has a nice tone and isn't retarded loud.
Nailedit187 is offline   Reply With Quote
