Old 08-12-2019, 01:01 PM   #1
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Winmax help
I have the nitrous outlet winmax controller. The problem I'm having is it's reading 0.5v for idle and when I set up wot it's reading 2.0 or 2.1v. I'm sure I've read it's 4.5 for wot but mine won't read it. I set it there and tried it and the stg 1 light flashes but doesn't stay solid.
Without being in front of the controller these are the settings I can remember
Stg 1....on
Rpm and TPS activation
Timing retard.....off. (retard via tune)
Gear......0
Cyl....8
Wot..... Sensor
Rpm on....4000
Rpm off.....6600
TPS on...89% (set it down from 95 to see if it would fix the issue of it not spraying)
Ign type...cop
I've tried programming the TPS with car running and in service mode (hold start button for 10sec) and I get the same voltage readings. TPS % displays seemingly accurate. I could set a camera next to it and watch during a pull (didn't leave enough wire to put it in easy view while driving).
I am using a jms pigtail on the throttle pedal. The same one they use for their voltage boosters. I used tlhe wire that they have for you to use. It was the blk/ylw or ylw/blk (don't remember which way it is atm)
Wires are soldered. I didn't use butt connectors so I don't think there's a connection issue there unless it's within the jms set up.
Fwiw hp tuners shows pedal, throttle body etc at wot. (99.6 or 96.9%). I could see about setting it to read the voltage but I imagine it sees it correctly if it's showing nearly 100.
Any thoughts on where my issue is?
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 09-05-2019, 11:28 AM   #2
jorgesvlog
Drives: 2019 Chevrolet SS
I know im not answering your question, but where did you tap into for the throttle position information to the winmax controller?
jorgesvlog is offline   Reply With Quote
Old 09-05-2019, 11:56 AM   #3
Dubchitts
Dubchitts's Avatar
I used a jms pigtail that they just started selling separate from the voltage boosters kits.
I would recommend it. Otherwise it's a very short yellow/black wire you have to tap into at the pedal
https://www.camaro6.com/forums/showt...php?p=10547742
Also my issue ended up being in the relay wiring. I had the 85, 86 backwards.
"Spitfire" 427ci
Old 09-06-2019, 09:55 AM   #4
jorgesvlog
Awesome! Thanks for the help! Will be doing nitrous in the future and this will definitely help! now we just need a plug and play solution for the rpm signal lol
Old 09-07-2019, 07:15 PM   #5
Dubchitts
Dubchitts's Avatar
I tapped into my 2step. Lol. But I seen someone had a clamp style but idk where
"Spitfire" 427ci
