10-26-2017, 02:00 PM | #15 |
Drives: 2018 HBM SS 1LE Join Date: Sep 2016
I got this fixed! I actually even live in the same area. Pardon my French but f**k freeway. They wouldn't even acknowledge the problem for the longest time even with videos showing it.
I went to Earnhardt (not a fan of their sales but their service is great). Make an appointment with a tech named Aaron and he should be familiar as we went through the same thing and he was able to figure it out (bad battery cable was my fix). 100% of the time I was given a rental so I wouldn't need a shuttle or wait around...freeway refused to give me one because they magically never had any available. Side note. Things they attempted were: removing the alarm as the BCM uses the same ground, regrounding all the BCM and head unit grounds, drove around with a pc hooked up (needle jump does not show up in the computer so it is purely instrumental which makes sense since the engine doesn't rev), and finally replacement of the battery harness. Interestingly I was eventually able to reproduce the issue at will by pulling up on my window switches with closed windows. Last edited by miketan; 10-26-2017 at 02:11 PM. |
10-27-2017, 01:58 PM | #16 | |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol // (purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills) // 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap // |
10-27-2017, 11:40 PM | #17 |
I believe that is the one... I can try to dig up the service record this week (I think I left it at work).
10-28-2017, 01:24 PM | #18 | |
Drives: 2016 Camaro SS 1SS Join Date: Apr 2017
10-30-2017, 10:37 AM | #19 | |
https://imgur.com/a/n44eK |
10-30-2017, 12:39 PM | #20 | |
Drives: 2016 Camaro 2SS Garnett Red Join Date: Apr 2011
I'm super happy with Chris at freeway, he gave me his work cell and is super fast to respond if I have any questions or ask about updates to the car. Side note, they are replacing my exhaust again because of the dam npp rattle, and also replaced my right passenger rear speaker because it was farting, also replaced the casing around the speaker too. |
10-31-2017, 07:57 AM | #21 | |
09-07-2019, 02:16 PM | #22 |
Drives: 2016 Camaro Convertible 2SS Join Date: Nov 2016
Thought I was the only one having this issue.
Background, 2016 Camaro 2SS convertible with A8 auto. Tach needle bounces around randomly at idle (just like in the video), or coming to a stop, sometimes just cruising in traffic. What is worse is I have caught the tach on the HUD doing it to, so I suspect it is not a gauge issue but a sensor issue. Guess it is off to the dealer then before the warranty goes out in Oct. (but good thing I bought the extended). Side note, had something similar happen in my 1988 Beretta GT (first car I ever bought). It had the digital dash option, and would randomly light up the entire dash, then go dark. Dealer ended up replacing dash before learning it was the primitive ECM acting up.
2016 2SS Convertible, A8, Dual mode exhaust, MRC, Nav, Stainless pedal kit, all-weather mat upgrade, SS center caps, Hurst billet shift handle, Camaro logo armrest
09-07-2019, 06:59 PM | #23 |
I am still having issues with my tach needle jumping uncontrollably. I just had it in the shop at freeway Chevy for two weeks and they were told how to fix it from the Chevy tach team, and they performed the fix, and they said it was no longer jumping, so I picked it up, and pretty much the second I drove off the lot, it started jumping again. My contact in the service department is Lonny, and I sent him a video within 30 minutes of me leaving and he didn't have words to explain why the issue still persists. I honestly am at my wit's end with this issue and this car as a whole, I've had nothing but issues with the car and I'm pretty sure that the car has been in the shop longer than I have owned it. This is/was the 4th/5th attempt at fixing the tach needle and still are no closer to the issue being resolved.
I've also had 4 completely brand new exhaust systems put in my car due to them breaking after 6 months of use. I've only owned the car for 2 years, I've been in contact with Chevy corporate and my advisor there has been nothing but fantastic, but, this is ridiculous. They even gave me a comprehensive component letter to help compensate me for my troubles, but taking it to a dealer and them having it for two weeks and then saying the problem has been fixed, and it not even being close to being fixed the second I get it back, for me was the last straw. I have officially asked for physical compensation for my troubles and am pushing for a heavily discounted 2020 Corvette at this point. |
08-13-2021, 01:17 PM | #24 |
Drives: 2018 CHEVROLET Camaro LS LGX/TR3160 Join Date: Apr 2019
I've developed a Speedometer bounce issue myself...Usually starts to happen when I'm on it for a while, like at 5000-6000+ rpm, right after a shift. The scanner shows my speed is changing, tried a new speed sensor, no good... Not sure where to go with this... It does affect my cruise control as well... otherwise everything seems to operate as it should. Any thoughts? Thanks!
LorenZo
2018 CHEVROLET Camaro LS -The Giant Black SEALION- LGX/TR3160 w/BOZE!!!!! ig: rapidtransit |
08-13-2021, 02:30 PM | #25 | |
https://www.camaro6.com/forums/showthread.php?t=586153 Its worth a shot as its cheap and easy to do. Good luck and if you add the ground cable please report back in my thread as I want to keep that thread alive to help as many people as possible.
08-13-2021, 04:11 PM | #26 |
Acknowledged, thank you. I will. I seem to be the only one with a Speedo issue... I don't know how related this is to the tach issue but I'm willing to try. I've had this car since new and it all started happening around 40k miles..... Shutting the engine down and restarting clears the problem.
LorenZo
08-23-2021, 11:10 AM | #27 |
So the grounding cable is too short for to reach the V6, I obtained a 24" 4 ga cable from the parts store. Unfortunately, is hasn't fixed my issue, but the engine does turn over a little quicker, so some points there...
My speedo goes crazy only if I get on it hard, normal driving its fine all day long, coming to a stop and shutting the engine down and restarting makes it all go away. I will say that cruising at highway speed and revving it up in neutral doesn't cause the problem, tis only when I'm in gear...I plan on probing the wires this weekend... I just don't think I'll find anything wrong there... I would almost think I have an issue with the reluctor in the transmission, but even that seems far fetched...
LorenZo
08-23-2021, 11:38 PM | #28 |
Drives: 2016 2SS Convertible Join Date: Aug 2021
Been having the same issue. Going to bring it in once the weather starts to change and I won’t be driving it anyway.
