04-15-2019, 03:19 PM | #15 |
Drives: BMW M3, ZL1 1LE Join Date: Mar 2019
I have this issue too and am hoping GM figures this out for us. They're replacing the mic for me shortly so hopefully they will check all of the seals while everything is apart.
04-28-2019, 08:36 PM | #16 |
its simply way to far away. needs to be in headliner above driver.
04-28-2019, 09:21 PM | #17 |
The mic replacement didn’t work and the dealer isn’t willing to help any further, so I opened up a case with GM.
04-28-2019, 09:45 PM | #18 |
Who Needs to KNOW?
voice rec is just dumb.. i have some contact entries w numbers as leading entry.. if i say numbers in any way.. can't find contact.. but then if i go by part of the name, it reads the numbers too "two hundred" - just learn to work around dumb stuff.
In that regard, even 2013 era ford sync worked better.
ing for grip.
04-29-2019, 10:28 PM | #19 |
Drives: 2019 Shadow Gray Metallic ZL1 Join Date: Jan 2019
My wife took it back in today. The service coordinator called me an told me there was a service bulletin out on the mic, but GM wouldn’t replace it. The suggested fix was to put sound deadening behind both mics. He told me that the Camaro being a sports car doesn’t have as much insulation and sound deadening as SUV or sedan. I asked him if they tested it this time and he said the tech that installed the sound deadening said it was 30% better.
When she picked it up she called me driving. I could still hear some road noise, but I could hear her a lot better. She doesn’t sound like she is in a tin can anymore. I may have to open up the A-pillar and see what they did. Maybe I can find something else to help. |
04-29-2019, 10:32 PM | #20 |
On a side note both times it has been in for mic service the first thing they did in the drop off bay is plug in a scanner. I guess they aren’t a mod friendly dealer.
04-29-2019, 11:50 PM | #21 |
I beleave they have to scan it now everytime they do anything on it. It's to verify the vin. Not to see if it's been tuned.
04-30-2019, 11:22 PM | #22 |
Soon to be Millionaire
Drives: Blue 2016 Camaro Join Date: May 2016
My car is so bad that people will straight up ask me roll up my window - EVERY TIME!
I want to find a fix once and for all... Anyone know what kind of mic and interface they use?
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look |
07-10-2019, 05:57 PM | #23 |
The poor mic performance is due to its location in the A pillar and excessive wind noise. Apparently they looked at moving it to above the mirror which helped, but that was shot down due to cost...
I'm actually working on designing a modification to mount the microphone to trim piece surrounding the overhead lights by the mirror. If it works in mine I plan on producing some more if people are interested. |
07-10-2019, 07:16 PM | #24 | |
Drives: 2017 Camaro LT, 1986 Camaro Z28 Join Date: Jun 2019
07-11-2019, 04:24 PM | #25 | |
07-11-2019, 05:11 PM | #26 |
GM just replaced my side mirror seal and it didn’t help either. They ordered a whole new mirror assembly but it came unpainted and they said they couldn’t match the flat black color from the 1LE package, so they they just took the seal off it it and transferred it to my existing mirror.
At any rate, I’ve given up on the warranty front and may take the pillar trim apart one of these days when I have some time. Working around the airbag makes me nervous though. |
08-23-2019, 11:50 AM | #27 |
Drives: 2019 chevy camaro 1ss 1le Join Date: Aug 2019
Has anyone taken the a pillar apart and snapped some pictures? It sounds easy enough to add a little insulation behind the mic to reduce background noise.
