10-17-2020, 11:44 AM | #211 |
Drives: ZL1 Join Date: Jan 2019
Alignment every oil change!
10-17-2020, 12:11 PM | #212 |
Steven just duplicated the issue at the end of that video.
I really don't think tire was the cause because mine did the same thing on the drag strip with stock tires. |
10-17-2020, 12:34 PM | #213 |
Drives: ZL1 1LE Join Date: Jul 2020
So quick update. Made a bit of a discovery accidently.
I was already coming to the end of the life of my Cup2s up front, and I corded them quicker then I thought. So in a pinch I bought some RE71Rs for the front (planning on going V720 ACR tires out back once they're back in stock) But tramlining is deff part of the problem, and my alignment might have shifted as well so I'm going to check it but the tires are without a doubt part of the issue. Now the rear end might squirm ever so slightly. but it's just not at all terrifying any more. I think what was happening was that the rear was tramlining, and then when you put a little input into the wheel the front would tramline as well, making the whole car feel like it was all over the road. With the front's no longer tramlining, the car all of a sudden magically is much much more settled. Like 75-80% better. Surprised, so I'll be checking alignment to make sure there are no changes there as well, but I can say from this that tire choice can certainly exacerbate this issue. So I think eventually as a community we'll figure out that if you have X brand tires, likely you'll want a different alignment, then another brand of tires. Funny enough the Re71's up front are MUCH more stable then the Cup2s. They feel more numb in Auto-X style maneuvers. But ripping up the backroads the other day they set into a corner and inspire confidence mid corner. So I'm not sure they're the most responsive tire, but it this case, a less manic nature actually helped the situation. |
10-17-2020, 03:43 PM | #214 |
Drives: 2018 ZL-1 Join Date: Jan 2018
I align my car every 2000 miles, and it is always out of spec.
10-17-2020, 04:15 PM | #215 |
10-17-2020, 05:53 PM | #216 |
10-17-2020, 09:13 PM | #217 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
If you have to align your car every 2,000 miles...you sir, have a mechanical problem.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
10-17-2020, 10:01 PM | #218 | |
But every time I take it in, it is out of spec by a little bit. And I have a full BMR suspension setup. |
10-19-2020, 05:44 AM | #219 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
DAMN
10-19-2020, 07:49 AM | #220 | |
10-19-2020, 09:52 AM | #221 | |
I actually brought the bolts to Firestone last week to have them installed, but they didn't quite get the message, and did not install them for some reason, though they did the alignment. Next time I have the car aligned, I will be more clear and have the bolts put in. |
10-19-2020, 12:12 PM | #222 |
Here are the before and after measurements. Not out a bunch, but enough that free alignment is worth it. This is after about 2200 miles.
10-19-2020, 12:25 PM | #223 |
ZL1 Believer
Would the following thread have anything to do with this thread? It seems to answer the issues you all are having with rear end alignment going on the blink.
https://www.camaro6.com/forums/showthread.php?t=502324 |
10-19-2020, 12:35 PM | #224 | |
Next time. |
