08-05-2013, 01:23 PM | #141 | |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
08-05-2013, 02:04 PM | #142 | |
2015 SS 6M
08-05-2013, 02:47 PM | #143 |
2015 SS 6M
It think I have a logical explanation why the TVS2300 in the GT500 CANNOT use a spring loaded coupler.
It appears that the coupler in that supercharger is mounted to pins directly connected to the rotor gear. They share the same compartment in the supercharger. Any debris released from the spring fretting on the shaft would likely damage the delicate teeth of the gears. Precision gearing and metal debris don't mix well. If that logic is accurate it would apply to any supercharger where the input shaft couples directly to the rotor.
08-05-2013, 03:04 PM | #144 | ||
Mid-Florida Camaro Club
Drives: 2019 ZL1 on Order Join Date: Jan 2011
In other words, given that people have been using the solid coupler as a way to resolve the rattle issue since 2009, and that there are no documented cases of problems being caused by this part by anybody that has switched to it thereafter, is it not fairly safe to say that in actual fact, despite the theory that goes against it, the physical evidence suggests that it is going to be just fine? Or given the lack of absolute verified evidence one way or the other, do you genuiely think everybody should just put up with the rattle? I guess at the end of the day, it is all a personal preference, and some people are more risk averse than others - they are likely to be the ones that still have a warranty e.g. yourself, and by default are not going to be switching to this solid isolator in any case. For the rest of us we have a decision to make, and I genuinely think that using the evidence and experience of all those that have gone before us with this swap is a perfectly valid course of action to assess the risk involved. And I'm not talking about the people selling the part, I'm talking about the experiences of the end-user. Oh, and at the Avatar change Quote:
I do - but this weekend she was away - and my car is also away at FSP getting built.....sooooo
08-05-2013, 03:23 PM | #145 | |
I meant it would be good to see a tear down of Joe's SC or one of the others making the squaking noise to see where the problem was at and what is making it louder than others. The other thing about the GT and 2300 is the shaft is driving the gears and the 1900 is driving the rotor and it has more drive shaft length. So there may be something to do with vibration at the rotors, or the momentum in the rotor may amplify the vibration, oscillation, etc.
08-05-2013, 03:30 PM | #146 |
Drives: 2014 ZL1m6 red hot #569 Join Date: Dec 2009
they did not remove the snout since they warrantied the whole charger. somewhere on the forums are pics of the intake and supercharger when they had it off but as I said snout was intact
08-05-2013, 05:45 PM | #147 |
This is interesting. In this article superchargersonline says they only use the spring isolator because it prevents gear damage. And this is the type with the coupler directly at the gear and in the same oil bath with the gears.
http://www.superchargersonline.com/i...age=page&id=57
08-05-2013, 06:12 PM | #148 | |
2015 SS 6M
08-05-2013, 07:16 PM | #149 | |
Interesting bit of Info from the latest person that is having his LSA supercharger replaced because of the rattle noise...
I guess we will find out soon enough....
08-05-2013, 08:30 PM | #150 |
Dry Heat My @ss
Drives: 2012 ZL1 SUMMIT WHITE Join Date: Mar 2012
This thread is soooooo entertaining. Gotta love it.
ps: I have the solid coupler.
2012 #1765: Xpel Clear Bra, 15% Tint, M2W, LPE GT9 Cam, Ported Heads & Snout, Upgraded Valve Train, 90mm TB, LPE Dual Fan HX, 2.55 Upper, 9.1 Lower (18%), Id850's, KB BAP, Roto-fab CAI, AR Stainless Headers, 673 rwhp, A6, Nothin but Fun!
08-05-2013, 08:36 PM | #151 |
As I understand it, that picture was for the 2012 ZL1 before the car hit the street. The CTSV guys were hoping the same thing a year ago. I doubt the new part number changes from a spring coupler, but we can keep hoping.
Actually, reading on the caddy forums seems the new part number has the same issue. Maybe it fixed bearings or other problems.
08-05-2013, 11:11 PM | #152 | |
2015 SS 6M
I missed this point but it's a great one. If the mass of the solid coupler is significantly more than the torsion coupler, that could cause a lot of unwanted vibration, more so if the solid coupler is not perfectly balanced. Also I wonder what elastic deformation may be occurring to the solid coupler as it spins at such high speeds.
08-05-2013, 11:18 PM | #153 |
2015 SS 6M
Just theorizing here, but what more perfect application for a fluid torque converter can there be. Torque transmission via fluid would almost negate any irregular torsional vibration transmitted from the crank. There would be sacrifices in increased lag most likely.
OR maybe a centrifugal clutch. As the input shaft reaches sufficient speed the clutch engages the rotors. Or even a frictionless magnetic coupling where magnets around the input portion of the coupling create a rotating magnetic field that caused magnets connected to the rotor drive to spin. Unless the input at the pulley was WAY overdriven I think all those would reduce the torque ratio enough to be impractical. But this... sounds interesting and appropriate...if it's good enough for our suspension... Patent #7,086,507: Controllable magneto-rheological elastomer vibration isolator A tunable vibration isolation device comprising a magneto-rheological elastomer (MRE), and methods of using such a device, are provided. By manipulating a magnetic field within the MRE the device's stiffness is controlled. The vibration isolator can be constructed to provide shock absorption in one, two and three dimensions. Coupling the tunable device to a sensor feedback and a control system provides fast and accurate vibration isolation and energy dissipation for shock events in a variety of applications.
08-07-2013, 01:17 AM | #154 |
Looks like you took it deeper than anyone else wants to go. Oh well.
