04-06-2021, 01:00 AM | #1 |
Drives: camaro Join Date: Apr 2021
Error with leds DRL replace
Hello, I just bought my 2013 Camaro SS, I changed the daylight bulbs to LEDs and I have an OBD error. Can we cancel the bulb failure on the OBD?
04-06-2021, 06:29 AM | #2 |
Drives: 2010 LS Join Date: Feb 2021
All my external lighting is LED, and I just live with the warnings...
You would need to put load resisters on them. I won't do that. The whole point of LEDs is lower current, well, load resisters put the current back up to incandescent wattage, so, no point in it, no energy savings. |
04-06-2021, 08:29 AM | #3 |
so you push x times the button of the comodo to erase error message ?
No possibilty to cancel this check in the OBD ?? |
04-06-2021, 09:06 AM | #4 |
I put LEDs in my DRLs and never had a problem .
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
04-06-2021, 09:42 AM | #5 |
04-06-2021, 10:00 AM | #6 |
Same 2011 that is in my avatar and signature. Just replaced them with Amazon LEDs and never had a code or problem. They did start to burn out single led's but I was going to replace them. Then came a front bumper conversion.
04-06-2021, 10:54 AM | #7 |
Drives: 2010 Camero 2SS RS Join Date: Oct 2011
same here, i have LED in driving lights, 2010 no obd errors
I got the link from someone on here and they match color to the halos, also did the converter that leaves them on while lights are on.
Corsa exhaust - custom tune - CAI - Subtump drivers and pass side boxes with Infinity kappa perfects - top speed i quit at 166mph chickened out
04-06-2021, 06:17 PM | #8 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
I put these in back in 2016 and have not had an issue.
The pic shows new vs old.....man my car looks so different now hahahha https://www.ebay.com/itm/224210680417
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
04-06-2021, 06:45 PM | #9 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
You can buy LEDs with the load resistors built in the bulb so you do not have this problem. They are typically the higher cost bulbs.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
04-07-2021, 12:41 AM | #10 | |
least. You would need to program the BCM module to stop it. VWs, have a program called VCDS where you CAN do it, turn the diagnostics off for lighting. Would not know where to begin with the Camaro, and if it's even possible. |
04-07-2021, 06:58 PM | #11 |
Drives: 2013 2SS/RS LS3 NPP Join Date: Jun 2020
I added these last year with no problems. Amazon will say they do not fit the 2013 Camaro, but in fact they do. The first pair I ordered had a different style connector socket. These are what you need.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
04-09-2021, 01:36 AM | #12 | |
bulbs. Those are 9005/9005 like sockets, not the 5202 like I have. So, when they say they do not fit, I think they're assuming you have the 5202 bulbs. |
04-09-2021, 08:54 AM | #13 |
I also have the LED's in my DRL's for the last 9 years and no issues.. And the DRL harness so they come on with the other lights. I have these..
https://www.phastekperformance.com/2...s-led-p13w.htm
Thread Tools | |
