04-05-2021, 04:49 PM | #1 |
Drives: 2010 Camaro SS Join Date: Oct 2020
Timing marks
Below is a picture of where I locked my flywheel prior to removing cam. I'm at the point of putting the timing chain back on and did not realize is was so far off. Is this close enough? If not what do I do at this point since the chain is off along with heads. Can I simply move the cam to where it lines up like the photo? To complicated things further the car is in gear with the battery disconnected. If I need to crank it to line things up better can I just hook the battery back up in the current state? I feel like the ECU is going to freak out. Thanks in advance I'm kicking myself for nit noticing this earlier....
Sent from my SM-F916U using Tapatalk |
04-05-2021, 05:01 PM | #2 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
No LS2 chain damper either
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-05-2021, 05:05 PM | #3 |
To me, it looks like the cam timing mark is slightly to the left of 6', whereas the crank timing gear mark looks slightly right of 12'. I think you are OK. If you want to make sure, just throw the car in neutral, re-install the crankshaft bolt and run it in with your fingers. It'll allow you to turn the engine over with a ratchet. You can then make two revolutions of the crankshaft, and both timing marks should re-align precisely at 6 and 12.
Let us know how it goes. -Scott |
04-05-2021, 06:00 PM | #4 |
04-05-2021, 08:18 PM | #5 |
#teamGPI
Drives: 2010 Camaro SS Join Date: Aug 2020
You definitely want it more lined up than that, I made sure mine was dead on, also recommend the LS2/dog bone dampener and new timing chain preferably the katech C5.R timing chain.
04-05-2021, 09:01 PM | #6 |
Since yall giving me such a hard time. I went ahead and gave the crank another spin and installed the damper.
04-05-2021, 09:39 PM | #7 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
You want it like this.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
04-05-2021, 09:42 PM | #8 |
Being off this little amount threw a cel and you could hear it was off.
04-06-2021, 06:02 AM | #9 |
Excellent you did the damper.. the original is known to fail. Make sure you get those Mark's spot on.
04-06-2021, 10:07 AM | #10 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
When I did mine it was a little off like yours and I could not get it to line up right on no matter what I did. Every time I put the chain on it moved ever so slightly like yours is. So I decided to let it go like it was and it was fine. So I don't know if yours will get any closer but I would try but if you can't I wouldn't stress about it.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
04-06-2021, 09:42 PM | #11 |
That's about as close as I can get it. She is torqued down and staying that way. On another note how do I know for certain that I got the alignment hole and cam pin in place. I put a streight edge across the block and it cleared the chain. Is that all I need to check?
04-08-2021, 03:19 PM | #12 | |
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
12-31-2021, 01:39 AM | #13 |
Drives: Chevy camaro Join Date: Dec 2021
I NEED HELP, HOW CAN I FINE THE SEQUENCE TO THE ROCKER ARMS?? WHICH IS PISTON # 1 ?? I BEEN HEARING ON THE DRIVER SIDE BUT I ALWAYS THOUGHT PISTON 1 WAS ON THE PASSENGER SIDE??? ALSO ONCE I GET PISTON IN LOCKED HOW MANY DEGREES I TURN BEFORE MOVING TO THE NEXT SEQUENCE NUMBER?? THANKS
Last edited by Allisgreat2002; 12-31-2021 at 01:42 AM. Reason: Forgot to mention make and model 2010 ss camaro 6.2l L99 |
12-31-2021, 06:23 AM | #14 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
