Old 04-22-2019, 10:42 AM   #1
Miamiguy1105
Drives: 2019 Chevy Camaro SS
2019 Camaro SS issue with ac on screen
Hi guys, newbie here to the Camaro world. I'm having an issue with my car when it sits over night and I go to start it the ac on the screen saids it's off but the ac is running physically. If I try to change any of the settings a message pops up on screen telling me the ac is off. I can get it to work again fine by turning off the car waiting a few and starting it back up again. Anyone else ever have this issue. The car is an 1SS if that helps thanks
Miamiguy1105 is offline   Reply With Quote
Old 04-22-2019, 11:10 AM   #2
ste1n
Drives: 2019 2SS
2019 2SS here. Same thing happened to only once. Next time I started the car, it worked as it should.
ste1n is offline   Reply With Quote
Old 04-22-2019, 12:07 PM   #3
Lithias
Lithias's Avatar
Drives: 2019 2SS Riverside Blue Metallic
For what it's worth, I also experienced this software bug. Manual AC controls still work but digital says it's off. Typically happens the first startup of the day when I DONT USE remote start. Chalked it up to the software update and software gremlins.
Order # WKXN0F 2SS Riverside Blue Metallic, A10, NPP, 56V
Ordered 9/15/18
1100......9/17/18
3000......9/19/18 TPW: 11/26/18
3300......11/9/18 TPW: 11/26/18
3400......11/12/18 TPW: 11/26/18
4300......11/22/18 BUILT! VIN: 1G1FH1R72K0123562
4B00......11/27/18 Waiting for Dispatch! Tentative delivery date of 12/11!
4300......11/28/18 Waiting for the train to Florida!
4200......12/5/18 SHIPPED!
4800......12/14/18
5000/6000......12/18/18 SHE'S HOME BOYS!
Follow me on Instagram! @the_3ngin33r
Lithias is offline   Reply With Quote
Old 04-22-2019, 03:27 PM   #4
Miamiguy1105
Yeah I'm thinking it's a software issue also just annoying
Old 04-23-2019, 08:25 AM   #5
gmw0181
gmw0181's Avatar
Drives: 2017 Camaro 2SS A8
I found a few bugs too in the radio console. Sometimes sound management is missing, the AC bug. Some bugs show up using remote start.
I read in a thread here if you use the remote to unlock then lock and use remote start the sound management will not disappear.
I also found unlocking and locking before startup got rid of most of the bugs in the radio console.
I figure it is a way to wake up the modules in the car before startup, just a guess.
For the last year or so I do this and I have had no problems with software bugs.
gmw0181 is offline   Reply With Quote
Old 04-23-2019, 08:47 AM   #6
Osbornsm
Drives: 2018 SS 1LE
Good fix... i lke the simple ones.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is online now   Reply With Quote
Old 07-06-2019, 10:38 AM   #7
Miamiguy1105
hey guys Ive got an update on the Climate control issue on the radio display. message below was from GM. apparently we were right its a software thing.
#PIT5663: Radio Displays Climate Off Message or HVAC Popup Displays Different Settings - (Mar 11, 2019)
Condition: At random the radio may display a pop up message “Climate Off” even though the HVAC system is fully functional. This can be repetitive in nature. Making any change to the HVAC system will make the message disappear. The radio may also display a HVAC popup when changing HVAC settings that does not match the selected setting (e.g. blower speed).
Cause: Software anomalies between HVAC and Radio may cause this popup to appear with incorrect or inaccurate HVAC information.
Correction Do NOT replace any parts for this concern. Engineering has identified the cause and is working toward a software solution. This PI will be removed and replaced with a bulletin once the software fix is available.
