Old 03-06-2019, 04:04 PM   #15
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
Sooooo...are we supposed to be using Dexos1 Gen2 (which is apparently the only kind of Dexos1 currently available) or Dexos2 for the LT4's? Is there a downside to using the Dexos2 anyway, otherwise?
rlarsen462 is offline   Reply With Quote
Old 03-30-2019, 07:09 PM   #16
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Dexos2 has better high temp durability (HTHS of 3.5 or greater) and common in the EU because it also has a diesel rating. My rule of thumb is if your oil temps reach 230F often (most people see max of around 210-220) you need an oil with an HTHS of 3.5+. Most xw-40s have an HTHS starting at 3.5, but very few xw-30s do except those spec'd for European cars (ACEA A3 rated).
The only downside to a Dexos2 oil might be slightly lower fuel economy, but we're talking .5mpg. Otherwise it is just more expensive.
wakespeak is offline   Reply With Quote
