04-05-2020, 06:28 PM | #29 |
THE GREEN GOBLIN
Drives: 2020 ZL1 Rally Green Met.10 Spd AT Join Date: Apr 2012
Same thing i did. Works great, no issues at all.
Rally Green Metallic, Sun Roof, 10 Speed Automatic.
Mild 2 Wild exhaust controller, Brandmotion Curb Alert. More to come. |
04-05-2020, 07:02 PM | #30 |
New to GM
Drives: 17 ZL1 91 LX 5.0 Join Date: Jun 2019
I'm confused. My zl1 goes up the 67" XT ramps just fine. Front and back...
04-05-2020, 07:05 PM | #31 |
New to GM
I have clearance no issues
04-06-2020, 09:06 AM | #32 |
Thank you Al Oppenheiser!
04-06-2020, 09:12 AM | #33 |
Drives: CTV5 V Blackwing on order Join Date: Feb 2020
I went with the 80's because they were 10 inches high instead of 8 and they are 14 inches wide instead of 12.
Previously owned a shorter (lower) pair and I just feel more comfortable with a little extra room underneath. Buy once, cry once.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10 2017 Ford Expedition |
04-06-2020, 09:51 AM | #34 |
Drives: 2019 SS Join Date: Apr 2020
I bought Rino ramps, 10 inches high 12 wide, perfect for oil changes and whatnot, cost was 46 bucks good to 12000 pounds.
04-06-2020, 10:00 PM | #35 |
New to GM
Negative. That picture just happens to have my car outside. It's usually inside. When I bought mine they were the ones everyone on here recommended, 10" high 67" long XT 2pc. I'm still confused what has changed that now all of a sudden they don't work for others....
04-07-2020, 08:19 AM | #36 |
Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
I think the difference might be with your 2017 ZL1. The 2018 and newer sit just a bit lower. Pretty sure they made some changes between years. Anyone correct me if I am wrong. Just enough to make the ramps touch. Like I said I didn't add much it was so close.
04-18-2020, 07:13 AM | #37 |
I love crepes
I have a set of two piece race ramps for sale of anyone is interested. Send me a PM.
04-20-2020, 01:06 AM | #38 |
Drives: 14 Silvy 1500 Z71; 20 Camaro ZLE M6 Join Date: Jun 2017
Looks like some of you with ZL1 1LEs are using the 67" and some are using the 80" Race Ramps. I know I definitely would like the 10" lift height that the 67 and 80" ramps provide to allow for extra room working under the car, but my concern is the approach angle of about 10* on the 67" and the 8-9* approach angle of the 80". My goal would be to not need wood blocks to help me start up on the ramps so just wondering which length ramp seems to work best for the ZLE in terms of not scraping the splitter/air dam pieces beneath the splitter. I looked at the 72" ramps too which have an awesome 6* approach angle but that is only 12" wide and only lifts to 8" so didn't really think that would be a good option considering the wide ZLE tires and desiring the 10" lift room to work under the car.
I also saw the 80" ramps can be turned over and used to help load the car into a trailer? Anyone use them for that too? That would be helpful to share the ramps with my dad to help load his 1986 or 2013 Camaros into his trailer for car shows. Should mention my 2020 ZLE is completely stock. |
