09-01-2020, 01:33 PM | #1 |
Drives: 16 Camaro SS w/ Roto-fab CAI Join Date: May 2009
Big Gulp Series 5" CAI by Roto-fab!
Roto-fab is excited to offer our newest addition to the Big Gulp® Series of cold air intake systems! With duct work nearly 20% larger in diameter than our standard 2012-15 ZL1 CAI, the Big Gulp® CAI was designed to meet the air demands of the fastest Camaros in the world. Don’t leave horsepower on the table - get the most out of your modifications with these key air intake design features:
- Innovative air box coupling method allows for solid mounting to the air box as the system transitions from our 6” air filter clamping surface. This coupling design also effectively seals out unwanted engine heat! - Air box seals effectively to the hood which allows for maximum air filter size and air box volume! It also utilizes the full factory air inlet to ensure low IATs and maximize performance. - Standard hardware for this system includes a 5” to 4 ¼“ hose coupler for 102-103 mm throttle bodies. 4” adapter PN 10132004 is sold separately for use with the OEM throttle body.(larger throttle body recommended) We use 100% silicone hose couplers to ensure lasting product quality. - 5” OD MAF housing and inlet elbow to maximize performance and airflow cross-section. We’ve molded a larger bung in the inlet elbow and we include ½” and 5/8” breather fittings to accommodate stock or upgraded PCV systems. - Our Polymer duct work is extremely effective in reducing heat transfer. Click here for more info: https://www.roto-fab.com/2012-15-cam...-woiled-filter Last edited by Roto-fab 1; 09-01-2020 at 01:45 PM. |
09-02-2020, 08:02 AM | #2 |
Drives: ZL1 Join Date: Dec 2016
What are the gains on the big gulp versus the original roto fab cold air intake on the ZL1?
09-02-2020, 05:29 PM | #3 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
YES!! Glad to see this product finally hit the market. I'll be picking one up in the future!
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
09-03-2020, 08:44 AM | #4 |
Drives: 2013 Victory Red ZL1 M6 Coupe Join Date: Dec 2017
Certainly will be adding this as well in the near future!
2013 M6 Victory Red Coupe | Roto-Fab Intake | Ceramic Coated Kooks 1 7/8” Headers | 2.55” Upper | 9.06” Lower | CSP Custom Grind Cam | DSX AUX & Flex Fuel Sensor | ID1050X | TR7IX | Taylor Wires | E2-X Ultra Catch Can |CSP Tuned W/ HPT | E85: 704/718 (SAE 5)| 93: 655/638 (SAE 5)
09-21-2020, 12:08 PM | #5 |
