11-21-2019, 09:44 PM | #1 |
Drives: 2016 camaro ss Join Date: Apr 2018
Installed LNC-2014 car doesn’t like it
Ok I installed per instructions disconnected everything from it got a second one did same thing. Car runs horrible with it no throttle response and throws code p2034 and p2319
I don’t have anything connect to it. Just placed in between coils. At idle I hit throttle it chokes goes lean then revs up. Anyone have an issue like this? |
11-21-2019, 09:45 PM | #2 |
It’s simple plug and play. I moved the harness on top of the intake even.
11-22-2019, 06:02 AM | #3 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
What is it?
11-22-2019, 07:35 AM | #4 |
2-step and timing retard.
https://www.lingenfelter.com/PROD.ht...4#.XddbPyVMHDs |
11-22-2019, 08:04 AM | #5 |
You should contact Lingenfelter.
11-22-2019, 09:16 AM | #6 |
I did I swapped plug wires and coils this morning per their advice same result.
11-22-2019, 01:28 PM | #7 |
Drives: Chevy Camaro Join Date: Jul 2019
Mine works perfect, if you have tried two, your doing something wrong.
Tags |
lnc-2014, nitrous, timing |
