10-21-2020, 06:35 PM | #1 |
Drives: 02 Camaro B4C Join Date: Nov 2016
How do you remove the fender flare adhesive?
Awhile back I purchased some Z28 rockers, flares, bumper covers, and front fenders.
I was finally able to remove the flares from the front fenders. Now I need to clean the old adhesive off the fenders & flares. The Service Manual says to use a 50/50 mix of isopropyl alcohol and water. I made the mix and used a cloth shop towel and rubbed on it for 15 minutes and can't see that it has done anything. I don't want to try commercial adhesive removers or acetone on the flares. Some of those will damage plastic. Any advise would be appreciated. Thanks Craig
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
10-21-2020, 06:40 PM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Goo-gone or WD40.
10-21-2020, 06:46 PM | #3 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
Xenit Citrus from Stoner. Use it to remove 3M adhesive gently.
10-21-2020, 06:50 PM | #4 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
I use goo gone its citrus base. Works well with some elbow grease...lol
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
10-21-2020, 07:45 PM | #5 |
If it’s 2 part adhesive, you’ll have a very difficult time with any citrus(goo gone) or wd40 until you get it removed down to a very thin layer. To get it to a thin layer, use a new razor and slice it very carefully as not to touch the paint. Once you get it thin then use googone or wd40 with scratch pad, but scratch pad will go through paint so something less abrasive is better but takes longer. Sounds brutal but the 2 part adhesive is a B&@“$ to remove.
The 50/50 is only for double sided adhesive residue. |
10-22-2020, 12:26 AM | #6 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
Maybe one of those adhesive removal wheels that doesn't burn the paint.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook. Follow: @5th_gen_z28_registry I track wrecked Z/28s Total lost -41 |
10-22-2020, 12:51 PM | #7 |
10-22-2020, 03:38 PM | #8 |
Well I have tried the 50/50, WD40, Goo Gone, & Acetone with no success. I also tried the adhesive removal wheel, like a giant eraser, with no luck.
From the look of it someone must have used a two part adhesive or panel bond. I will try scraping with a razor blade. I'm not worried about the paint the car is being repainted.
10-22-2020, 04:09 PM | #9 | |
10-22-2020, 04:43 PM | #10 |
No the adhesive isn't hard. It is rubbery.
10-22-2020, 06:32 PM | #11 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Maybe try using a heat gun or even a hair dryer. Obviously you don't want to go wild and melt anything but get the adhesive warm enough to remove it with a plastic scraping tool.
10-22-2020, 07:56 PM | #12 |
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
try anhydorus methanol 100% no water, straight no water added. its used on the plexiglas adhesive, and will solvate most adhesives.
Methanol is the smallest alcohol molecule will solvate the adhesive better, or it it needs some umphh.. use a blend of d-linonene and methanol. you all know d-linonene as goo-gone, it has the solvency power of acetone, so the alcohol will buffer it a little. personally I'd try 75 methanol 25 goo-gone if methanol doesnt cut it as needed. Important..add minimal water..that really buffers the effect of any solvent. The other caveat? Check the blend on an area out of sight in the trunk first.
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
10-22-2020, 09:57 PM | #13 | |
10-22-2020, 11:26 PM | #14 |
Jumanji
Plastic scraper or wooden stir stick. Sharpen with 200 grit sand paper and do small areas. Keep it sharp. I've this wooden stir sticks on aircraft panel adhesive and it worked very well, just kept it razor sharp. Also doesn't damage paint.
