Old 05-13-2018, 11:47 PM   #113
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by mbnwa View Post
I'm not sure I follow X1 is the black connector, X2 is the grey connector I did not find anything that shows the VT on the black connector, I do agree that some discrepancy does exist on the Performance Data Recorder PDF for example circuit 5483 on the PDR UQT schematic it states X2-11 is the VT wire however on the physical harness as well as X203 short cable VT is pin 10 - I am assuming that the PDR PDF may not be accurate as the rest of the color codes match up on the other documents / wire harness I am using the wire harness schematic to come up with the connection points.
PDF says X1 is grey.
File Type: pdf K161 VEHICLE PERFORMANCE DATA RECORDER X1 (UQT).pdf (919.1 KB, 68 views)
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 05-13-2018, 11:47 PM   #114
mbnwa
Drives: 18 NGM ZL1 1LE
yeah you posted just as I was editing my post to say the following
EDIT: I see where you got X1 and X2 being reversed K161 VEHICLE PERFORMANCE DATA RECORDER X2 states BK and K161 VEHICLE PERFORMANCE DATA RECORDER X1 states GY
mbnwa is offline   Reply With Quote
Old 05-13-2018, 11:50 PM   #115
nighttowl
nighttowl's Avatar
In the previous post of the double check of the wiring im going by circuit numbers.
im not going to buy another connector to mate into the short recorder harness, but im going to plumb it so to speak. looks like most if not all of the grey connector goes to the radio. I cannot find where wire #5842 goes yet.
Old 05-13-2018, 11:55 PM   #116
mbnwa
In the above post of the double check of the wiring im going by circuit numbers.
5842 seems to be ground A11 X1 does not seem to have a ground on it, I also can not find any reference to 5842 in the service manual.
I revised my chart on page 7 again, please let me know if I have anything out of order from your own cross check so we can have two sets of eyes on it, Thanks for checking the work I posted as well it's nice to have a 2nd pair of eyes on it.
Old 05-14-2018, 01:05 AM   #117
mbnwa
K161 X1 Pin 12 - BU/VT - Audio Request Signal - Circuit #1551 - Goes to Ground 305
I think K161 X1 Pin 12 - BU/VT - Audio Request Signal should be Circuit #4609 and goes to A11 X1 P17
K161 X2 Pin 12 - BK/WH - Signal Ground - Circuit #1551 - should go to ground
Old 05-14-2018, 01:19 AM   #118
mbnwa
It also seems that a discrepancy might exist for X20 SD Card Reader in the PDR PDF it states that X2-4 is ground and X2-6 is battery + HOWEVER here is the discrepancy in X20 MEMORY CARD RECEPTACLE X2 (UQT) it states X2-4 is Secure Digital Card Reader Low Reference and X2-6 is Secure Digital Card Reader Controlled Control to top this all off X202 references Secure Digital Card Reader Low Reference and Secure Digital Card Reader Controlled Control however pins 6 and 7 that it states would be those connections are plugged with no wire, so the assumption here is that power and ground is accurate for X20 X2 - nighttowl any thoughts on that?
Old 05-14-2018, 03:00 PM   #119
mbnwa
This states it's for option i05 so not sure if this is the same with i06 however #5842 is referenced on the document K31 NAVIGATION CONTROL MODULE X2 at PIN location #6
Old 05-14-2018, 03:20 PM   #120
radrace19
Drives: Pontiac G8 GXP
Check out the price on the SD Card connector
This is actually the cheapest I found it...
Just an FYI on this one
Here is the connector $ .50 ea
https://www.mouser.com/ProductDetail...Zl2DZ1tw%3d%3d
1998 Pontiac Grand Prix - 11.24 @ 121
2009.5 G8 GT (Liquid Red)
GXP fascia conversion, GXP diffuser
2009 GXP M6 (MSM) #405 586rwhp/495tq
TVS2300, CTS-V Fuel System, Cam 222/230 116 lsa, Monster Lever 4 Clutch, American Racing 1 7/8 headers, rear Brembo's w/working Parking brake
11.91 @ 119
radrace19 is offline   Reply With Quote
Old 05-14-2018, 03:21 PM   #121
Nitro66215
Nitro66215's Avatar
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV
Mouser is awesome. I found a lot of my terminal and connector stuff for the HUD upgrade / Cluster upgrade!
2018 2SS Vert - Hot Wheels - Indy 500 #30
2017 ZL1 Vert - M6 , SIM, CFW, NAV
2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-(
Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 -
Heads-Up Display - DIY
2011 CTS-V - Black / Black - SOLD. :-(
2013 ZL1 - Black / Black - SOLD. :-(
2010 2SS - Indy 500 Pace Car. - SOLD. :-(
2002 Z28 - Pewter / Black - SOLD. :-(
Nitro66215 is offline   Reply With Quote
Old 05-14-2018, 03:34 PM   #122
mbnwa
Thanks, I just ordered two of them. How did you cross reference the GM part number to get this part number? It would be nice to be able to do that with some of the other connectors.
I did cancel my Amazon order for the 90$ plug and will see how this work when it comes in.
Old 05-14-2018, 03:38 PM   #123
Nitro66215
Nitro66215's Avatar
For reference.... on the service manual.. look up the service connector or OEM part that is in the pinout for that connector. See if you can find it. Then use the description given as well for a reference. Knowing the manufacturer is part of the help.
For instance the 32 pin connector for the cluster.... 32-Way F 0.64 Micro-Quadlock Series (BK) ... .I searched for the MQS series connector with 32 pins... came right up.
Old 05-14-2018, 03:41 PM   #124
mbnwa
Thanks
Old 05-14-2018, 03:55 PM   #125
radrace19
Yes, I helped Nitro find some other connectors. (Greg@Pace)
The terminals for the above connector is SAIT-A03T-M064
I already use that connector & terminals for another project here so when I saw it I new what part number it was.
So add the required number of those also.
-Greg
11.91 @ 119
Old 05-14-2018, 03:56 PM   #126
Nitro66215
Nitro66215's Avatar
I already use that terminal for another project here so when I saw it I new what part number it was.
-Greg
You are the man, Greg! BTW.. HUD and MOST wiring complete!
