09-15-2022, 02:13 PM | #1 |
Drives: 2023 Camaro 2SS and 2012 Camaro LS Join Date: Sep 2022
New Camaro owner as of today! Hopefully.
Hey everyone, just wanted to introduce myself. I live in the Pacific Northwest and love cars. I have owned Mustangs, Challengers and others but never a Camaro. I am about to become a first time new Camaro owner. At least if I make it though the 4hr train trip north to pick it up. I am currently sitting in the Amtrak station waiting to go.
09-15-2022, 02:24 PM | #2 |
good luck
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
09-15-2022, 03:39 PM | #3 |
Drives: 2021 3LT RS A10 Join Date: Nov 2021
Welcome dude. You wouldn't be at the Amtrak station in Lacey, would you? Where you getting the car from?
09-15-2022, 03:42 PM | #4 |
Drives: E92 BMW M3 Join Date: Oct 2012
An Amtrak station the day the rail almost shut down to go pick up your first Camaro.
I think it is awesome your first Camaro, will be the last Camaro model year. Good luck on your travels, congrats on the new car....post some pics!!!
J-Rod Built and Matt@FSP Tuned |
09-15-2022, 04:48 PM | #5 |
09-15-2022, 04:54 PM | #6 |
to the forums, TheYankeeMarshal, hope everything goes well with your delivery. You purchased an absolutely amazing car at the last possible moment
Please do post some pictures once she's all yours.
09-15-2022, 05:06 PM | #7 |
Oh, here are some delivery checklists if you fancy thoroughly checking out your new car, given how long you traveled to pick it up. Feel free to use them or ignore them as you wish .
Some of these require driving the car for a while, you will want to find a dealership local to you for remediation under warranty. Good luck and enjoy your first Camaro Quick checks Front fascia – color match to body. Fit to hood (gap and level, flush hood to fascia) Paint defects – Blemishes, debris, dirt, scratches, and thin coverage Paint thin or missing in door jambs, under hood, wheels, etc. Defroster vents leaking cold air onto windshield in A/C mode, causing condensation build up Differential noise when cold and turning Coolant leaks at full operating temp Fluid leaks from engine, trans, cooler lines A/C recirculation door sticks, pops NPP exhaust butterflies – for rattles when running Squeaks or rattles over bumpy surface Door rattles from speaker bass Wind noise leaks Complete checkup Request no "dealer emblem" (the painted advertisement for where you bought it) Request no detailing If you don't need a front license plate, tell them not to drill / install mount for it. Exterior Paint All surfaces / panels have consistent color, coverage Scratches / swirls - Inspect using bright light, note locations Note any excessive orange peeling (there will be some on these cars, it's expected, but shouldn't be excessively bad) Look for any other imperfections Body Dents Missing / incorrectly installed trim (GFX, bow ties, emblems, decals, etc) Gas cap closes flush with body Gaps between panels are uniform and appropriate (problems were reported with hood alignment and side doors rubbing on panel in front when opened). Headlights / taillights unscratched, unbroken All LPO items installed / factory versions made available to take home Correct wheels Correct brakes Trunk Check interior paint coverage (around seal, hinges, interior of trunk) Check trunk open / close / lock /unlock Under hood Condition / presence of paint where paint should be Check hood for open / close Correct Tire Pressure Front / back turn signals work Brake lights work Backup lights work Interior Check all infotainment system functions (radio, XM, OnStar, play from USB, wireless charger) Check all DIC displays (cycle through) Check HUD, if installed Check disco lighting, if installed Check heated seats / ventilated seats / heated steering wheel if installed Run adjustable seats "stop to stop" in all directions Check center console (open /close, interior) Check AC/heater function Rear window defrost Fit & finish of all interior trim Window operations, both windows Interior lighting Door locks / remote unlock Check fuses (two fuse boxes, one underhood, one below trunk floor liner) to ensure all fuses fully seated Test Drive Remote start (if equipped) works Gas gauge works Dual Mode Exhaust (if equipped) works Cycle through drive modes Alignment (car doesn't pull to one side or another even when you let go of steering wheel) Paperwork Sirius XM subscription confirmed for 12 months (not three) OnStar activated (don't give them any credit card info(!) ) Claim your original window sticker Double-check warranty start date Tax, tag, title, loan... Bonus: Get the "event history" and/or factory build sheet for your car
09-15-2022, 05:11 PM | #8 |
Hmmm. I grew up in Vancouver, moved north 30 years ago.
09-15-2022, 05:28 PM | #9 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Nice... Be sure to post pics when you get your car. Congrats
09-15-2022, 05:34 PM | #10 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Congrats It’s an incredible car!0
09-15-2022, 06:22 PM | #11 |
you are not the same Yankee Marshall on youtube reviewing guns?
09-15-2022, 10:52 PM | #12 |
Looked that guy up......hmmmm
09-16-2022, 06:50 AM | #13 | |
is the same guy
I use to watch his ch a while back but not much into guns as much so dont really watch many gun ch anymore
09-16-2022, 07:04 AM | #14 |
Hmmmm?
