09-05-2022, 02:34 PM | #1 |
Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
Whats the best gear ratio for a 10 speed LT1/SS?
Has anyone experimented on what the best gear ratio is for the 10 speed 6.2s?
09-06-2022, 04:50 PM | #2 |
Are you looking to change ring and pinion? If that’s the case, you’ll need a new setup.
09-06-2022, 05:33 PM | #3 |
What's in it from the factory is pretty much optimal with the factory tire height. If you put a 28" drag radial on it for better traction, then the 3.27 from a V6 car might be beneficial.
2016 NFG 1SS A8
