08-22-2022, 11:49 PM | #1 |
Drives: Chevy camaro SS Join Date: May 2020
Windage tray
Does anyone know if the SS LS3 has a windage tray? If not how hard is it to install one in the GM(factory) oil pan?
08-23-2022, 03:43 PM | #2 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Yes the ls3 has a windage tray stock from the factory.
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
08-24-2022, 11:31 PM | #3 |
PKeen: okay, I did know if it had one or not. Iwas goning too buy one and install it. Thank you.
08-25-2022, 06:53 PM | #4 |
Your welcome!
08-25-2022, 08:50 PM | #5 |
Improved Racing has a better option than OEM version.
https://www.improvedracing.com/ls-vo...-tray-kit.html
Orange Krush II
09-09-2022, 11:23 AM | #6 |
olBlue75: Thank you for the information and website. I may have to get one of these. Is it hard to install?
