09-05-2021, 01:34 PM | #1 |
Drives: 2016 Camaro Join Date: Oct 2017
Upgrade rear 2SS Brakes to ZL1 14.37-inch
I would like to know if the following GM parts make for the 14.37-inch x 1.10-inch, (365x30mm) ZL1 rear brakes on a 2SS.
GM Brembo rear 4-Piston Brake Calipers, part #84300395. Cost: $471.38 for the pair. GM Non-directional 14.37-inch x 1.10-inch, (365x30mm) Rotors, part #23369743. Cost: $109.16 per rotor. I didn’t list the backing plates, and brake lines because I just need confirmation on the calipers and rotors working together first. Thanks!
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
