01-02-2011, 05:12 PM | #1 |
LS9 Cam in a NA LS3
I see a few threads on this topic but don't see that anyone has come to a conclusion.
I'm considering swapping an LS9 cam into my LS3 in anticipation of adding an E-Force Supercharger next year. How will the car run pre blower once I drop in the LS9 cam? It would be nice to get a few more hp between now and when I add the blower. Any help in this area is greatly appreciated. |
01-02-2011, 08:42 PM | #2 |
I have the e force installed and am looking at the cam install now along with torque convertor and everyone tells me that there is more to be offered by going with a custom grind rather than this ls9 cam. Yes this cam is cheap but vie been told you may be leaving 30+ hp on the table by trying to save a couple hundred bucks on the cam itself because the install price will be the same. Good luck
Edelbrock E-Force
Stainless Works Lts Roto Fab CAI Magnaflow Street Cat-Back DOD Delete Forgestar F-14's and Pedders XA + PKG Custom grind cam from Cincy Speed ADM dual fuel pump ADM AF/Boost gauges FTI 3200 convertor Hurst shifter Cincy Speed Build and Tune 540rwhp |
01-02-2011, 08:49 PM | #3 |
9691 & 97586
Drives: 2010 SS, 1999 SS, 1993 Z28 Join Date: Mar 2009
I think the average pick up is around 20 to 30 rwhp... thats with a tune too. You may wanna search or look in the V8 engine mods thread for better answers.
01-02-2011, 08:59 PM | #4 |
Thanks for the info...I know MTI and Comp have blower cams too. Just wasn't sure if the car will run right since I don't yet have the E-Force?
01-03-2011, 09:16 AM | #5 |
Drives: 2011 SS/RS LS3 Join Date: Oct 2010
The car will run fine and the cam will give you around 20hp N/A. I'm sure it will be worth more with a blower. Great street manners and idle. N/A you can use your stock pushrods and valvetrain. You might want to upgrade the springs for F/I. That being said, to install it with stock springs should MUCH cheaper due to less work for the install. I think you can order the cam from GM parts direct for $98.
01-03-2011, 09:17 AM | #6 |
I hack cars.
Drives: Lots ;) Join Date: May 2009
It'll run fine, I ran my G8 GXP LS3 without a blower with the cam and it was great actually.
Chris White
Some uhhhh cars. |
01-03-2011, 01:51 PM | #7 |
Sounds good! My next issue is unfortunately I don't have the know how to do the install myself so I'm going to pay to have it done. I was quoted $1500 by a local shop to install a Dynatech header and the cam. In our area we don't have many speed shops to compete on price so not many options. Is it just me or does this seem a bit high? Thanks for the info!
01-03-2011, 02:20 PM | #8 |
What does $1500 include? Cam? Headers? pushrods? springs? clips?
Edelbrock E-Force
01-03-2011, 02:21 PM | #9 |
That would be about right on a LS3 for a cam pkg and that is them supplying all parts.
Edelbrock E-Force
01-03-2011, 02:31 PM | #10 |
No...that is just for labor on the header and cam swap. Parts would be on me.
01-03-2011, 05:17 PM | #11 |
Drives: 2010 2ssrs Join Date: Nov 2010
If you have to pay to do the work spend the extra money and buy a real cam.you will be alot happier in the long run.
01-03-2011, 09:31 PM | #12 |
Any suggestions? What cam would you recommend? Something that will work well with the Blower to come and work well until that time.
01-03-2011, 10:48 PM | #13 |
So do any of you think $1500 labor is too much?
01-04-2011, 05:34 AM | #14 |
Does that include a dyno tune? For that type of install price you should get a bigger cam with pushrods and springs. You will definitely need a tune with a bigger cam. The Livernois stage 1c cam would work well with a blower, have great drivability, and make some nice power N/A. If that price is without a tune I'd RUN away from that deal.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
LS 9 internals for LS3 so I can use the LS9 Superchager on the LS3 | 1985airborne | Forced Induction - V8 | 5 | 08-09-2010 09:57 AM |
LS3 with cam | allmotor | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 07-12-2010 07:49 AM |
whos running a ls9 cam in their ls3? | ddavis | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 07-10-2010 08:30 PM |
LS3 Cam Package makes over 500rwhp!! | Late Model Racecraft | V8 Bolt-Ons & Tunes | 45 | 07-19-2009 01:58 PM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
