Old 01-20-2020, 08:33 AM   #1
CamaroRed_SS
CamaroRed_SS
CamaroRed_SS's Avatar
Drives: Red Hot 2016 Camaro 1SS
2016 Camaro SS Heater Problem
This morning on my way to work I had my heater going full blast & it was working good until I slowed down and it started blowing cold air. I remote started it before I got in as well and noticed the heater was not warming the car up like it should even tho it was set on High full blast. What can cause that to happen, I hate getting in the car at 5:30 am & it’s freezing inside. Thanks.
CamaroRed_SS is offline   Reply With Quote
Old 01-20-2020, 08:52 AM   #2
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
Sounds like low coolant!
Sweptwing is offline   Reply With Quote
Old 01-20-2020, 08:53 AM   #3
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Have you checked your coolant(antifreeze)levels under the hood? In my experience sometimes when the coolant level is low the heater doesn’t work that well until you add some to bring it back up to the recommended levels. Hope this helps!
Old 01-20-2020, 08:55 AM   #4
LT4Greg
LT4Greg's Avatar
Sweptwing is thinking like me!
Old 01-20-2020, 09:07 AM   #5
CamaroRed_SS
CamaroRed_SS
I’ll check it after work & go pick up coolant hopefully that’s the problem, thanks guys
Old 01-20-2020, 09:13 AM   #6
ctrlz
What is your coolant temp gauge showing? It should move to the 200 degree mark (approximately) and stay there. If it drifts up or down while you are driving you may have a sticky thermostat.
Old 01-20-2020, 09:59 AM   #7
LT4Greg
LT4Greg's Avatar
Let us know what you found out!
Old 01-20-2020, 04:51 PM   #8
CamaroRed_SS
CamaroRed_SS
Quick question do any of you guys know what the little dex-cool reservoir is right behind the big coolant reservoir? I know it’s got a tiny hole up top & I don’t think I’ve ever put anything in there, am I supposed to pour coolant in that little bottle too?
Old 01-20-2020, 06:17 PM   #9
LT4Greg
LT4Greg's Avatar
Yes you are supposed to put coolant in there too! Your owners manual shows what the level should be, but yes it has coolant in it too! I would say fill it up to half mark and the large reservoir should be full.
Old 01-20-2020, 07:55 PM   #10
CamaroRed_SS
CamaroRed_SS
Thanks for the help, the coolant was a little low so got it all filled up. I’ve got an appointment to get the car aligned tomorrow at noon & they will be taking a look at it as well to make sure everything else is good to go! Thanks everyone for the help I appreciate it
Old 01-20-2020, 08:49 PM   #11
CamaroChriSS
CamaroChriSS's Avatar
Drives: 16 1SS M6 Black -previous 00 Z28 M6
That was exactly the way my 4th gen Z28 acted when the water pump started to fail. Best of luck getting it sorted out - hopefully an easy fix!
CamaroChriSS is offline   Reply With Quote
Old 01-20-2020, 08:54 PM   #12
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
If the coolant level is ok then I’ll put money on it the heater core needs to be flushed. Seen this many times on many different cars and machines.
