04-01-2018, 08:05 PM | #1 |
Drives: '18 SS 1LE Join Date: Jul 2016
LS3 Hot Cam?
I recently lost all oil pressure while driving, shut the car down and had it towed to my house. it now sits in my garage, waiting on the mellings high volume oil pump i ordered.
I figured, while im at it, i should cam it. I've heard of these GM hot cams which use your factory valvetrain and make 480hp stock to the crank. Im running Vararam intake, ported throttle body, 1 7/8 long tube headers, high flow cats, solo performance exhaust, and a dynosteve tune. My question is, if it's possible to simply only swap the camshaft with a GM "hot cam", while keeping stock valvetrain (i may change springs anyway), why is everybody spending $1400+ on a big cam and lifters, pushrods, springs? I'm trying to make some decent power, but still maintain daily driver-ability on a M6. Is the hot cam the way to go? Do i want more lift rather than duration? Somebody please chime in. I'm trying to purchase a cam or kit tomorrow! Thanks for the help. |
04-01-2018, 08:45 PM | #2 |
Drives: 2015 Camaro SS convertible L99 Join Date: Nov 2016
$1400 makes it reliable, you dont need new lifters since is a ls3 but you need trunions.
04-01-2018, 08:54 PM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
Bo White ran this cam with stock valvetrain with great success PM him about it. very similar to hot cam but this one is better because it has more lift. Call Lingenfelter about it, this should be fine with stock valve springs.
https://www.lingenfelter.com/product...l#.WsGM-4jwaM8 https://www.lingenfelter.com/PDFdown...L210055297.pdf |
04-01-2018, 09:31 PM | #4 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Since you have a dynoSteve tune are you gonna stay with him? if so he would be the best to spec a cam since he is doin the tune..right? plus I would never do a cam swap and keep stock springs nor the P/R's...just sayin...once you add all the pieces up? gonna cost ya regardless so may as well go for the gusto! peace
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
04-01-2018, 10:01 PM | #5 |
The stock cam has .551 lift on the intake so the GT1 cam at .561 lift or the hot cam would be fine with the stock springs. just keep it under 6300
04-01-2018, 10:48 PM | #6 |
guess I should have said one of my very first mods was to ditch the POS stock springs and P/R's..along with the trunnion upgrade this STOCK cam car will kick a lot of a$$....just sayin...peace OP and hope YOU spend ur monies wisely...g'nite!
04-01-2018, 11:15 PM | #7 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I ran stock rockers for 134k miles and 2 cam swaps.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
04-01-2018, 11:51 PM | #8 |
thanks for the fast response. im most likely going to get a set of .660 dual valve springs no matter what, unless it is not needed, or if the weight of the dual springs is not worth it.
Is it absolutely necessary to swap the pushrods with a cam like GT1? Has anyone ran the GT1 cam with stock pushrods and just new springs and trunion kit? Is it necessary to upgrade timing gear/chain? I cant tell if the GT1 is 3 bolt or not. How much power over stock is this GT1 making? Looking for a nice choppy idle and decent gains, but still maintain drivability in town while being easy on the valvetrain, but might as well make it worth it. Can anyone recommend anything? Thanks again. |
04-02-2018, 12:07 AM | #9 |
Good to know. Someone said you ran the GT1 cam on a completely stock valvetrain, how did it go? Would you suggest running this?
I believe the stock valve springs are lighter than dual springs, what would you recommend? Can i run this GT1 without replacing anything, or would it be risky? |
04-02-2018, 03:05 AM | #10 |
I ran it with just 7.400 comp pushrods
04-02-2018, 06:25 AM | #11 | |
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
04-02-2018, 10:21 AM | #12 |
I thought in your original post that you wanted a cam that you could use with the factory valve springs. If you are going with new springs I would use a different cam all together.
04-02-2018, 11:06 AM | #13 |
Drives: 2011 Camaro 2SS Join Date: May 2016
Nightfury or bust....
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
04-02-2018, 01:47 PM | #14 | |
