11-25-2022, 08:07 PM | #1 |
Drives: 17' Chevy Kamaro SS 6 speed Join Date: Mar 2022
Anyone with over 100k miles on a v8 6th Gen Camaro yet?
11-25-2022, 09:43 PM | #2 |
PKG4U
It’s been asked and posted several times, I think there are a few on Facebook and at least one with over 200k
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
11-26-2022, 12:29 PM | #3 |
Drives: Ferrari F40 Join Date: Sep 2022
Not sure if you want to chat with owners or just know if they exist, but check out any of the big car buying sites like autotrader. Plenty of 100k+ mile 6th gens.
11-28-2022, 06:22 PM | #4 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Homer from Canada has over 200K on his 2017. And that was from several months ago. Probably has more now.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
11-29-2022, 06:01 AM | #5 |
I am at 104k on my 2017 1SS. I can give a breakdown of the few problems I have had if you would like
11-29-2022, 02:28 PM | #6 |
Drives: '16 2SS M6 Join Date: Aug 2019
I'm at 106K
In the last 60K that I have owned it, I've had to replace the battery, both front O2 sensors, spark plugs, front brake pads, one front hub bearing, and tighten the oil pan bolts. A/C compressor wire that controls the variable displacement solenoid broke in the harness about 6" from the compressor (hard area to access). Pulled the wire out of the harness as close to that area as I could and ran a new wire down to the compressor. Other than that, no real issues with the car.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer Last edited by easttxss; 11-30-2022 at 10:04 AM. |
11-29-2022, 03:20 PM | #7 |
Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
11-30-2022, 06:15 AM | #8 |
I will try my best to remember
Transmission shudder at 21,000 miles- fixed with correct fluid flush Oil pan leaking between 21, and 30,000 miles -fixed under warranty Transmission temperature sensor failed causing the P0700 and P0711 code fixed with new harness and fluid refill $500 Coolant hose going to the oil cooler, 4 inch piece of hose split 70,??? miles $168 and the last thing was the rear differential went out at 90,000 miles and was $2900 for new rear carrier and drivers side axle from GM and labor But to be fair the first 11,000 miles life of this car was a Enterprise Rental car. It is also my daily at over 300 miles a week plus a few trips to the dragstrip. I am not easy on her so I can't and won't complain about the money spent over the last 4 years. Last edited by dmcmahan60; 11-30-2022 at 07:55 AM. |
11-30-2022, 07:27 AM | #9 | |
PKG4U
Decent. I’d take that over my experiences! Thanks for the write up D
11-30-2022, 07:59 AM | #10 |
Taylor, I might add that two high school friends are service writers at Landers McLarty Chverolet and another friend in the parts department for the body shop. And alos they shorted me 4 quatrs of oil on one of the free oil changes and called them out on it:( Got extended warranty on the engine and it only went back to them for the rear differential change a few months ago. Sorry you had a bad experience:(
11-30-2022, 08:04 AM | #11 |
Thank-you, dmcmahan60.
Jim G |
11-30-2022, 08:16 AM | #12 |
11-30-2022, 04:36 PM | #13 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
It really seems like with these cars, the bulk of the problems come earlier in its life...
TCS Shudder Power Steering Failure I've had both of those happen to me, but after fixing those the car has been pretty reliable. |
11-30-2022, 08:12 PM | #14 |
Drives: BVM 1SS Join Date: Oct 2016
Im at 65k. Have had to replace the thermostat really. Coolant hose at the bottom of the engine came off Saturday but was able to limp it to a Caddac dealer after the temp gauge pegged twice.
$600 and good to go. There is it least 1 ZL1 owner on FB with over 115k miles and no issues. |
Thread Tools | |
