Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > 4 Cylinder Bolt-Ons and Tunes
Old 11-21-2019, 10:04 PM   #1
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
AFE intakes in stock and on sale at Juiced Motorsports
U
nique One-Piece High Quality Housing W/ Sight Window:
A custom CAD designed roto-molded housing made from heat soak resistant material eliminates the use of multiple components and ensures the coolest air intake charge available. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene. A urethane plug is also included if you wish to completely seal the auxiliary air inlet. (US PAT 9440175) For Filter-to-Housing Interface.
High Quality Tube:
This system uses a high quality plastic CAD designed, dyno-tuned, roto-molded intake tube to achieve maximum power gains while maintaining a perfect fit. Also included is a high quality billet aluminum crankcase fitting provided for easy installation.
High Quality Scoop:
A high quality CAD air scoop guides cool ambient air to the performance air filter.
Large 3-Layer Performance Air Filter:
This Momentum GT intake system was designed around the largest filter possible to allow maximum performance and filtration. This cylindrical filter has a large oval (6-3/4" x 4-3/4") flange and is 9" tall inverted top Pro DRY S filter media. The Pro DRY S performance air filter features 3-layers of progressive finer porosity synthetic media providing maximum convenience with 100% polyurethane frame for long life and multiple cleaning cycles.
Premium Hardware:
Premium stainless steel clamps and a silicone coupling are used for strength and durability while also providing the most secure installation available. Momentum intakes are designed with fewer parts for a quick and simple installation.
Note:
This intake system is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles.
Don't forget code CAMARO6 at time of check out or give us a call.
We can install these as well and we love to do before and after dyno pulls!
We carry & install all the hottest brands for your 5th/6gen Camaro. Get awesome deals & install rates! Call or Pm us for your CAMARO5/CAMARO6 discount. 224-63-JUICE or INFO@JUICEDMOTORSPORTS.COM ST CHARLES IL
Juiced1 is offline   Reply With Quote
Old 12-13-2019, 07:17 PM   #2
Juiced1
Juiced1's Avatar
Great deals with code CAMARO6
Old 12-30-2019, 09:05 PM   #3
Juiced1
Juiced1's Avatar
AFE systems rock
Old 01-23-2020, 09:21 PM   #4
Juiced1
Juiced1's Avatar
Nice power gains
Old 02-07-2020, 09:13 PM   #5
Juiced1
Juiced1's Avatar
AFE makes a great intake
afe, i4 intake, intake
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
