Old 11-13-2019, 11:25 AM   #15
RacingBrake
Drives: Camaro
Originally Posted by Heartbreaker View Post
I bought a rebuild kit for the ZL-1 front calipers. I did not see a kit for the rears.
The rear caliper for G6 ZL1 is the same as G5 SS/ZL1 and G6 1L1 (28/30x30mm ht)
https://www.racingbrake.com/SearchRe...p?Search=BC-42
Complete listing for G5 & G6 calipers:
https://www.racingbrake.com/category-s/7383.htm
RacingBrake is offline   Reply With Quote
Old 11-15-2019, 02:12 PM   #16
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
How much of an improvement over the stock OEM ZL1 caliber pistons and seals is you rebuild kit in terms of dealing with heat?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 11-22-2019, 02:53 PM   #17
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
or just use Ti shims
Old 11-22-2019, 03:40 PM   #18
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Ti shims just haven't been enough in my case. Still cooking dust boots/seals
driven2exceSS is offline   Reply With Quote
Old 11-23-2019, 09:14 AM   #19
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Who is the source for the Ti shims?
Old 11-23-2019, 11:12 AM   #20
TrackClub
TrackClub's Avatar
If you continue to use stock pads (which run pretty cold in comparison to some higher torque ones) you will likely not have to rebuild anything anytime soon.
Also, if your pistons arent sticking there is no point of rebuilding anything yet. Rebuild kits dont guarantee that you will not have to rebuild again no matter how good the kit. Spending money before you see issues is a complete waste imo. Brakes are consumables including calipers. Eventually any caliper will need a rebuild, or get replaced. But much depends on type of pads.
Hope this helps. Cheers!
Old 11-23-2019, 05:20 PM   #21
driven2exceSS
I used Girodisk 1mm Ti Shims from: https://www.knsbrakes.com/c/home
Old 12-05-2019, 09:01 AM   #22
driven2exceSS
UPDATE:: Warren over at RB is stating the availability of both Dust Boots/Seals, and Cut Stainless Steel Pistons, are about two weeks out!!
Old 12-07-2019, 06:58 PM   #23
Mountain
Mountain's Avatar
The 2016+ SS and 2017+ SS 1LE rear calipers should be exactly the same spec. Your listing says otherwise...
Old 12-07-2019, 08:36 PM   #24
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Look at a set of Z06 pistons for the 6 piston calipers a lot cheaper than RB an are essentially the same.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 12-30-2019, 01:40 PM   #25
driven2exceSS
UPDATE:: This is the latest on the "High Temp" rebuild pieces and parts... Any further questions or concerns I would recommend reaching out to them direct, their email has worked well for me. Not sure how often they troll the forum
"Hello Scott,
Pistons are in stock.
Dust boot required some re-work on tooling for fitment tolerance resulting from a fitment test (about 2 weeks ago). New sample shall be ready in about 2 more weeks when I will let you know as soon as the test is complete and available so we can release the kit together.
Thank you for your patience & Happy New Years.
Warren"
Old 12-30-2019, 02:23 PM   #26
TrackClub
TrackClub's Avatar
Sounds like work/testing still in progress.
Happy New Year all!
Old 12-30-2019, 03:45 PM   #27
driven2exceSS
Happy New Year all!
A safe and Happy New Year back at you up there in that there Canada 'eh! It's already been way too much time away from them there tracks 'eh! lol True eh!!?
Seriously though...it has already been too long!! Cheers to ringing in the New Year and it's much anticipated and appreciated track season!!
Old 12-30-2019, 06:23 PM   #28
TrackClub
TrackClub's Avatar
Haha! True indeed, eh?! My season is waaay too short!
Thank goodness for iRacing lest I'd have to resort to heavy drinking Best to you and yours! Cheers!!!
