Old 07-25-2019, 01:05 PM   #1
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Arrow E85 Flex Fuel Plug-n-Play Complete harness
Hello all. I have about 20 (twenty) complete E85 harness assemblies for 2016+ Camaro SS cars. I was (am?) building these for a supporting vendor, however, I have a surplus that I need to clear out. These are truly plug & play harnesses that do not require any cutting or splicing of ANY factory wiring.
This harness comes with the Continental Flex fuel sensor, 3/8" quick-disconnect fuel fitting, custom length wiring harness complete with pre-terminated ECM wire with the correct ECU terminal.
The ECM will still require tuning to be able to read the sensor and adjust fueling based on ethanol content.
Complete kit is $165 shipped.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
e85, flex fuel, sensor
