Roto-Fab
Old 10-20-2009, 12:45 PM   #57
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Can you please explain what are good number for each test?
Fuel Trim: is it good or bad to have a positive or negative %
Timming: I know that less is safer for the engine, but less HP
Knock: dont have a clue
IAT and Temp Climb: best guess is that more heat is bad.
Hopefully you can clear this up for the rest of us that dont know THAT much about engine data.
thanks
JM
JM10 is offline   Reply With Quote
Old 10-20-2009, 12:48 PM   #58
600hp-lpe
Drives: 2010
Originally Posted by SSOOCH View Post
I am just shocked at the Hennessey CAI results! And it costs $500!!
I almost ordered that thing!!
Just goes to show... Looks aren't everything.
The Hennesey wins the best looking...
600hp-lpe is offline   Reply With Quote
Old 10-20-2009, 12:49 PM   #59
nickruta
Drives: 2010 black camaro
thanks
JM
nickruta is offline   Reply With Quote
Old 10-20-2009, 12:50 PM   #60
Kunk2301
Drives: 2010 SS RS Camaro
Great job, appreciate all the efforts from everyone involved.
Kunk2301 is offline   Reply With Quote
Old 10-20-2009, 12:51 PM   #61
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Originally Posted by Croathlete View Post
Dyno sheet?
Ask it from ss1_2010 its on his car and it over 410 hp.
Originally Posted by nickruta View Post
can someone just explain what the fuel trims mean and if its good to be positive or negative. Theres a big swing from -5% up to +15 just wondering what this means? Anyone help?
Yes i can that is the # over or under what the E38 is set up at . So let say that the OEM is set up to run a 10 to 1 AFM it will be - or = that % number so you see If it is set up at 10 to 1 and is -5 it is running 9.5 to 1, and if its +15 it is running at 11.5 to one, if we know what it is running in the first place.
And to do that you need a wide band in the tail pipe or in the o2 senser.
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-20-2009, 12:51 PM   #62
Capstone
Capstone's Avatar
Drives: .
I'm very happy to finally have some clear direction from an impartial tester. Thanks Jannetty. My order has already been placed for the intake that demonstrated the best overall performance, ease of install, price and appearance.
I think one further step in the process that would show a clear ranking would be to assign a 1-5 point system to each category so an overall "score" is arrived at.
Capstone is offline   Reply With Quote
Old 10-20-2009, 12:51 PM   #63
kellyjrt
kellyjrt's Avatar
Drives: 2010 CAMARO ABM 2LT
Like the other guys, does fuel trim mean that if its in the negative it is using less gas and getting better MPG's while keeping power?
kellyjrt is offline   Reply With Quote
Old 10-20-2009, 12:54 PM   #64
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i really would have liked to see a true cold air kit like the BWOODY kit,, they have been just keeping up with customer orders and do not have extra to send out at this time. hopefully another test in the future with units that did not make it for this test
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
camaro1 is offline   Reply With Quote
Old 10-20-2009, 12:56 PM   #65
96CAMaro
96CAMaro's Avatar
Drives: '02 Impreza 2.5RS
I wonder how K&N and SLP would fare against these and other CAI's. Hmmm.
96CAMaro is offline   Reply With Quote
Old 10-20-2009, 12:57 PM   #66
camaro1
camaro1's Avatar
negative fuel trims mean that the engine is running rich and the pcm is pulling fuel away from its fuel calculation to get the o2 readings were it wants them
positive fuel trims mean the engine is running lean and the pcm is adding fuel to its calculations to get the o2 readings were it wants them
when in closed loop the pcm is constantly trying to keep the a/f around 14.7-1, the fuel trims are the computer modifying/adjusting to keep the a/f the same
Old 10-20-2009, 01:03 PM   #67
MSG'
MSG''s Avatar
Drives: 2010 1SS Camaro
thanks for pasting a pic up for us guys at work, I know which one i am buying now
MSG' is offline   Reply With Quote
Old 10-20-2009, 01:09 PM   #68
yellow1
Drives: 1SS 6 SPD
my impression of the results = CAI's are a waste of money. ~$400 to gain 5 hp?
I would rather set my hair on fire..
yellow1 is offline   Reply With Quote
Old 10-20-2009, 01:09 PM   #69
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
gmpp should have submitted a air box as well.
same efficient package, with a better flowing dry filter.
as far as wasting money on 5 hp.....thats stock car tersting.
throw some headers and some boost into things, and see
what gains are to be had. the header guys prolly wont like
intakes hovering above the header.
i am getting my headers thermally coated to help keep exhaust gasses hotter,
and hopefully prolonging heatsoak a tad.
hot ss is offline   Reply With Quote
Old 10-20-2009, 01:12 PM   #70
Jayhawk500
Jayhawk500's Avatar
Originally Posted by Crowley View Post
Look forward to checking out the results once I am home. I can't get to the spreadsheet from work.
Thanks,
Crowley
+1
Jayhawk500
2010 2SS/RS, Six speed, Rally Yellow w/ Black Painted Stripes, Boston Acoustic Stereo, Polished 20" wheels, Solo Mach X Catback Exhaust, Solo HF Cats, Halltech CAI, Full Dash & Door ABL, ABL Lit Homelink Buttons, HUD Installed, Ride Tunes, Full Electric Passenger Seat, Fbodfather signed, VIN # 4492, PAID OFF!!!
2010 Yellow 2SS/RS with black painted Stripes...$37,000.00; Ride Tones sound system and remote...$ 40.00; Seeing the kids faces (Young and Old) light up and almost wet their pants....Priceless!!!
Jayhawk500 is offline   Reply With Quote
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 08:33 PM
aFe Stage 2 Cold Air Intake NOW SHIPPING from ECSpeedSound! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 44 11-13-2010 03:45 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 02:11 AM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Cold Air Intake xsofa 4th Generation Camaros 2 08-13-2009 05:40 AM
