10-20-2009, 09:07 PM | #155 | |
i'd actually would love to see dyno graphs of the results. showing the gains across the board. that will show more, as well as the air fuel ratio's. |
10-20-2009, 09:40 PM | #156 |
Drives: 2010 VR 2SS/RS A6 Join Date: Oct 2008
MR. TED , thanks for your time and the info..
Intelligence plus character that is the goal of true education.
BrianC. :flag2: |
10-20-2009, 09:46 PM | #157 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
So can anbody tell me which CAI was the best and worst preforming in the test results. I think I know just checking.
10-20-2009, 09:49 PM | #158 |
Drives: DD- 15' Chevy SS Sedan Join Date: Oct 2009
it seems to me like the main reasons for any variation greater than 1-2 hp is simply due to placement of the MAF, and modification of A/F ratio. IMO if these were all teseted WITH their own tune, all with generally close IATs would be almost exactly the same hp/tq. they all have similar high flow filters (knit pick, but they are generally the same on an NA engine like this not drawing all that much air) and, that being said, it wont even be a large improvement seeing as the stock box gives reliable IATs.
it would really just come down to one's favorite fit and design according to which one to buy, obviously excluding intakes with noticably higher IATs just my .02
10-20-2009, 10:02 PM | #159 | |
With similar to stock fuel trims and a larger than stock air filter, High flow cotton gauze style, and smoother path for air to travel and a Large SEALED air box to the outside air source, there are some significant gains to be had at 10 + HP and TQ for the Dollar. Fuel trims Are very representative of how well the system is designed as well as the MAF calibration, we started with -3% as a baseline so subract that number from the others and you start to see a better picture. Ted.
www.jannettyracing.com
10-20-2009, 10:04 PM | #160 | |
Drives: 2SS RJT RS/Sunroof Join Date: Aug 2009
Is there a benefit in getting a CAI if your adding a supercharger or smething as oppossed to keeping it stock? May have aske this before, sorry if I have. Just wondering |
10-20-2009, 10:04 PM | #161 |
Master of Medicine
Drives: 4th Gen Join Date: Oct 2008
Its a shame we can't run them on the track, that is the ultimate test anyway...too many variable to extrapolate though...
I think the clear message here is, don't worry about which intake your getting, just get one, because the stock setup sucks...especially if you are making BIG power. Alot of this is splitting hairs...if your after that last 10th then get a NE, Fastlane or ADM...otherwise just get whatever, or better yet, make one yourself.
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
10-20-2009, 10:05 PM | #162 | |
Resident Expert
Drives: Supercharged 2010 Camaro SS Join Date: Jul 2009
10-20-2009, 10:05 PM | #163 |
when are you taking the fuel trims?
10-20-2009, 10:08 PM | #164 | |
10-20-2009, 10:12 PM | #165 |
After install of each kit and clearing Fuel trims, they were data logged during a loaded drive cycle up through the gears several times, cruise and acceleration and deceleration rolling in and out of the throttle and Idle.
These cars learn faster than anything I have ever seen in past, thankfully because this test could have taken a lot longer with older cars. Ted.
10-20-2009, 10:17 PM | #166 | |
10-20-2009, 10:19 PM | #167 |
G-Force Addict
Drives: 2010 SS/RS A6 Join Date: Jul 2009
Ted: Can you let us know what order you ran the CAI's in? Curious...Thanks.
10-20-2009, 10:21 PM | #168 |
The order they are on the spread sheet.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 08:33 PM |
aFe Stage 2 Cold Air Intake NOW SHIPPING from ECSpeedSound! | AJ@ECSMotorsports | V8 Bolt-Ons & Tunes | 44 | 11-13-2010 03:45 PM |
List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
Cold Air Intake | xsofa | 4th Generation Camaros | 2 | 08-13-2009 05:40 AM |
