TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 04-28-2013, 07:41 PM   #267
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Originally Posted by blufin View Post
It couldn't hurt. Report back if the fuse pull does the trick.
You have a pretty quick car and must be a real good driver your stock time is awesome.
What was the DA on that run?
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
102SS is offline   Reply With Quote
Old 04-29-2013, 10:29 AM   #268
blufin
blufin's Avatar
Drives: Fire Engine
A quick check with Dragtimes shows that the DA was anywhere from -500 to -750 depending on what time the run was.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 05-05-2013, 03:45 PM   #269
102SS
waiting at the tree
102SS's Avatar
New PB ....but it can still do better.
I only blew 2 runs out of 10 today by accidently hitting the paddle shift on the line
My best run was
60ft 2.078 1/8th 8.697 at 83.04 1/4 13.375 at 105.46
I had the TC and air on :oops:
Old 05-10-2013, 05:27 AM   #270
Neumatic
Drives: 2010 Camaro 2SS M6
Well, I broke her after going racing Wednesday Night fun night. On the way back it drove pretty weird, so I took it to my dads after I got off work Thursday. We had it on the lift and he went through the gears and you could hear the throw out bearing. After he shut it off he hit the clutch pedal again and then the throw out bearing failed and we got a nice puddle of brake fluid on the floor. Not what I wanted to spend the money on but o well, should have ordered one when I realized one wasn't in the clutch kit I ordered and knocked it out in one drop of the transmission.
But ran a best of 12.08 @ 117. Had a good bit of 12.1X's to boot after starting the night out horribly. Rolled through the lights twice and car wouldn't go into second twice. Which both were probably because of the throw out bearing being ready to go out. Im just glad It didn't blow going down the track.
Neumatic is offline   Reply With Quote
Old 08-05-2013, 06:28 PM   #271
102SS
waiting at the tree
102SS's Avatar
New PB Stock
DA was 1445ft
Race weight 4150 just over 1/2 tank of 94
Tires Hankook 275/40/20 rear 245/45/20 front
60 ft 2.043 1/8th 8.664 at 84.30 mph 1/4 13.342 at 105.48mph
I think this tank will run a 12 in the mineshaft air of Oct/Nov.
Old 09-26-2013, 03:05 PM   #272
Neumatic
Went to the track last night and had some awesome DA (800-1100), so I figured Id run pretty good. I was wrong, I ran slower with the same 60' as I have ran in 2300+ DA, MPH was down ~3mph then what it typically runs. Wish I had the means to data log it last night. Only made 3 passes and 12.008 was the best I could do
Old 11-20-2013, 06:27 PM   #273
blufin
blufin's Avatar
Drives: Fire Engine
It's almost racing season again down here! I'm starting to get antsy.
Sold
Old 11-20-2013, 09:16 PM   #274
Neumatic
Mine ended the beginning of last month when I toasted another clutch. TH400 is in the works though, clutch issues solved.
Atleast 5 months before our tracks open back up.
Old 03-02-2014, 08:06 PM   #275
crl214
crl214's Avatar
Drives: 2010 CGM 2SS LS3
First passes in my car tonight. Just CAI w/ scoop, and MBRP catback for HP mods. BMR rear suspension mods as well. On street tires...
12.665 1/4 mile ET
111.45 1/4 mile trap speed
1.988 60' time
Couldn't complain, considering my first pass was a 13.45@109.9 (I bogged it badly). Second pass was 12.75 before the final 12.66. Wanted to shoot for 12.5xxx...but ran out of time
crl214 is offline   Reply With Quote
Old 03-02-2014, 08:07 PM   #276
12.665 1/4 mile ET
1.988 60' time
Very solid... practice practice practice
Old 03-03-2014, 06:34 AM   #277
crl214
crl214's Avatar
Thanks. I was pretty happy for a first time in this car. Clutch is tricky to me in this car (weird, high engagement point). You got it, practice, practice, practice!
Old 03-17-2014, 11:31 PM   #278
Lvz2881
Drives: 2014 2SS 6SPD
Best pass out.of 4 so car,Only mod is MGW.
13.94 @ 105.8
2.23 60FT
And she was a wheelhoppin'!!!
Took advantage of the BMR sale.and.already ordered toe.links, trailing arms and bushing inserts.
Hopefully to put a major.damper on the wheelhop.
What is recommended for.a.shift point?
I was shifting about 6200.
James
2014 Camaro 2SS 6Spd, Black/Charcoal leather
MGW, JDP Clutch Reloc, Hill Start Assist deactivated, APEX catch can, Muffler Delete, BMR rear arms, links and bushings awaiting install..
1995 Trans AM, M6, 6spd
1980 Malibu, LS Turbo build on the cheap!!
Lvz2881 is offline   Reply With Quote
Old 06-07-2014, 02:16 PM   #279
FKNGRSY
Drives: 2014 1SS
Took my 2014 ss out for the first time last night. Had a hell of a time getting the car to 60ft. ended up just slipping the clutch at 2000 rpm because anything more and I would spin all of 1st. Here's my best time:
60ft.--2.302
330---6.097
1/8---9.080
mph--83.07
1000-11.605
1/4--13.710
mph--108.87
Buying some Drag radials today haha. Also, dont know how much of a difference it makes, but our elevation here is 2,200 ft above sea level.
FKNGRSY is offline   Reply With Quote
Old 09-25-2014, 08:49 PM   #280
goalddinn
Drives: 2012 Camaro SS
Need some real solid answers
I have a 2012 Camaro SS that has a modified LS3 engine Magnuson Super Charger 12 pounds boost and a comp cam kit. 391 gears and a manual Tremec 6060 trans.
I put M/T Drag Radial ll's onto 20 inch x11 rims. actual tire is P305/35R20.
I ran them only once and couldn't get any traction off the line and spun them hitting second gear too.
I called M/T and the guy told me that these tires are not for a manual trans due to their configuration - too hard and no give in the sidewall for manual trans only designed for automatics. Funny, the first guy I talked to at M/T told me these are the right tires.
My question is what tire/wheel combo and or suspension mods should I make so it can hook up and put the power it has to the track. The best run I had on it was 12.03 at 120mph and 60' is only 2.143. I know it can run low 11's because of my prior experience driving a 10 second Chevelle. It is pulling hard through the traps.
Any real suggestions are most appreciated.
goalddinn is offline   Reply With Quote
Shouldn't we be comparing this to the new Mustangs? StoutFiles 5th Gen Camaro SS LS LT General Discussions 176 07-23-2009 04:26 PM
0-60 and 1/4 mile times (fastest production cars) patriotpa 5th Gen Camaro SS LS LT General Discussions 17 05-09-2009 07:29 AM
0-60 and 1/4 mile times. shank0668 General Automotive + Other Cars Discussion 28 07-19-2008 08:54 PM
1/4 mile brooks Off-topic Discussions 2 06-14-2008 01:30 AM
