09-05-2019, 11:11 PM | #15 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Can you clarify regarding the DCT30's? You melted them on the track? I'm not familiar with R12's, who makes them?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
09-05-2019, 11:15 PM | #16 | |
09-05-2019, 11:16 PM | #17 | ||
Wow that's great to know, I may very well try these, thanks
09-06-2019, 06:55 AM | #18 | |
Drives: ISO ss 1le Join Date: May 2018
R12 is made by gloc. DTC 30 i essentially melted. I got them too hot and they separated from the backing plate and crumbled. They are not made for heavy track cars, probably fine on the street though |
09-06-2019, 06:57 AM | #19 |
I think what he means is that the same pad should not be used for street driving, and tracking with slicks. Which, I’m in agreement with, a pad that is acceptable for good street use really shouldn’t be used with a slick as its not going to have nearly enough stopping power for slicks.
09-06-2019, 07:27 AM | #20 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
R12 is G-loc's third step up in their track-rated pad ladder, and it's essentially the same pad as Carbotech's XP12. FWIW, I'm not the only one finding that 10's last slightly/somewhat longer than 12's. As long as you aren't needing the extra temperature capability of the 12's, anyway.
What makes me uneasy about Hawk's DTC30/Street Race compound is that mu falls off a cliff at just over 1200°F / 650°C. I'm afraid that without quite a bit more experience you might not feel them going away on you in time. I'm not at all sure that I would. I do trust at least the general shape of Hawk's or any other pad mfr's curves without worrying if the "exact" temperature at any given value of mu for any given batch is precisely as plotted or within some unknown plus/minus amount . . . I think I'd trust mu to be within ±0.02 before trusting °F/°C to be within 25°. Norm
'19 WRX 6M (the family sedan . . . seriously) |
09-06-2019, 07:29 AM | #21 |
Drives: 1LE Join Date: Sep 2017
What group do you run in? How much seat time do you have? Number of track days?
09-06-2019, 08:11 AM | #22 |
BTW I've used Pirelli DH take offs and and only got 3 sessions on them. After that I was off by a second. They are not cheaper in the end then new Hoosiers in my case.
09-06-2019, 11:00 AM | #23 |
Drives: ZL1 1LE Join Date: Oct 2016
I have indeed run the stock pads with a few different tire combinations including SC3R's, NTO1's, Hoosier R7's, and DH take-offs. They worked for all the tires. With that said, they WILL fade. But it is a very linear, consistent and manageable fade. I never felt they truly impacted safety or lap times. You can run them all day and they won't destroy your calipers either.
I finally ran a set of DTC70/60's this past event and I really did not feel a huge improvement. They generated a few hundred degrees more (I have temp stickers on calipers), which in turn caused some fluid issue. They also after one event turned all four calipers into Brownbo's. All in all, taking into account the extra heat, "destruction" of the calipers and marginal improvement in braking performance, I can not say I find them worth it. I will be giving them another go in two weeks at a different track, so we will see if my opinion changes.
09-06-2019, 11:31 AM | #24 | |
I run 70s and smoked a caliper. RB pistons now with DBA rings and they feel spectacular! |
09-06-2019, 11:34 AM | #25 |
Are those pistons available for the ZL1 calipers? Do they get rid of the rubber boots entirely?
09-06-2019, 11:40 AM | #26 |
09-06-2019, 11:46 AM | #27 |
tems Ordered: Price: Status:
1 of : Save 10% on Complete front caliper rebuild components for Corvette ZR1, Camaro Z28, Gen6 Camaro ZL1 [Dust Boots:12 ea. High temp. (Blue) See disclaimer below] $520.80 Shipped |
09-06-2019, 11:47 AM | #28 |
Tags |
brake pads, friction, temperature, tracking |
