06-27-2017, 06:43 PM | #15 |
Drives: Gone: 2017 Camaro SS Join Date: Dec 2016
I didn't realize it had adjustable spring perches! Wow. The adjustable camber is cool too.
This car almost fits into a new category (perhaps the Viper ACR was already in it). Insurance companies often/typically don't allow for coverage of cars with "modified" suspension. This really isn't any different. If you someone made extreme erroneous adjustments to their spring perches and camber, there could be safety concerns from an insurance company perspective. We don't know right now, but I don't think the springs are different between various Camaros with the same suspension type and different engines. We know the V6 1LE was only greenlighted for production if there were "no new part numbers." You have a 300lbs weight difference, but that's <10%. Can you really tell if your front suspension is suddenly 10% stiffer? It might ride 1/4" higher. In the case of the ZL1 1LE setup, you may be able to resolve any such difference with the adjustable spring perches. Last edited by Snrub; 06-28-2017 at 10:08 AM. |
06-28-2017, 01:18 AM | #16 | ||
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
The more I read about this suspension, the more I want these on my car. It sounds like they spent tremendous amount of time designing the whole suspension and handling of this car with Race ABS, aluminium bushings, custom calibrated E-diff..etc..etc
http://www.caranddriver.com/reviews/...t-drive-review There was an event at another NorthWest track called Area 27. I wish I knew so I would be there and video of the car and some more info on the suspension can be found here: Quote:
06-28-2017, 06:43 AM | #17 | |
Drives: 2016 1SS Join Date: May 2016
06-28-2017, 10:08 AM | #18 |
I wonder how realistic this suspension setup is for a the street. Perhaps the best option for fitting on other cars is to simply buy only the shocks and use softer springs.
"While the chassis mods make it a fantastic track weapon, this car is somewhat compromised on the street. Not overly so, but you’ll want to avoid every pothole due to springs that are three times stiffer than those of the regular ZL1." http://www.caranddriver.com/reviews/...t-drive-review The differences between the various other springs is relatively small. "As a result of the decision to hard-mount the dampers to the car—and this is me being charitable—ride quality is not great. Being less kind—especially if you’re on ripped up, lumpy pavement—the ZL1 1LE’s ride flat-out sucks. It’s brutal, and over big bumps at speed, the rear end seems to run out of travel. That’s the trade-off for supercar handling everywhere else. Can you live with the car as a daily driver? Yes. Just avoid potholes like the plague." http://www.motortrend.com/cars/chevr...t-test-review/ |
06-28-2017, 05:14 PM | #19 | ||||
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
honestly, from having tein coilovers on a cavalier, and custom made ones on the dodge charger I ran, hard mounting coilovers isn't really a deal breaker to most. especially when you can adjust camber for the track in a few minutes. I read the other quote from the mags also above, about the spring rates are 3 times that of the normal spring rates... Quote:
12kg/mm=671.9 lbs/inch Then there are the stock spring rates for the SS 1LE and a few aftermarket manufacturers: Non-MRC SS Rates: 137 lbs/in (Front) 577 lbs/in (Rear) Hurst: 150 lbs/in (Front) 420-550 lbs/in (Rear) Eibach Rates: 160 lbs/in (Front) 121-691 lbs/in (Rear) 1LE Rates: 178 lbs/in (Front) 539 lbs/in (Rear) Source: http://www.camaro6.com/forums/showthread.php?t=475647 So with that in mind, the BASIC coil springs on the BC Racing coilovers are 2.45 times (nearly 2 and a half times stiffer) than OEM Non MRC SS Rates are in the front. and just 1.16 stiffer in the rear. granted for some, this will pose a problem, but so would the bc racing coilovers. I think for most, the price may be a bit much, but for those who have done coilovers before....AND WERE OK with em it shouldn't pose much a problem. 2 of my last 3 cars, I ran bc racing coilovers, and the one before that, I used b-g racing coilovers from rksport. the stiffer rates aren't always that much of an issue as long as you have a strut/damping to control the spring. Quote:
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
06-28-2017, 06:38 PM | #20 | |
Drives: Red Hot track candy Join Date: Oct 2009
Great explanation, thank you.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
06-28-2017, 09:09 PM | #21 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Keep in mind that there's only a 138 lb difference between a base 1SS manual and the ZL1 1LE (according to GM). 3823 lb for ZL1 1LE vs. 3685 lb for the 1SS. Add options to the SS (such as 2SS package, sunroof, etc) and that 138 lb gap closed.
I suspect the full ZL1 1LE suspension kit (springs/dampers/swaybars/links) will be a perfect track upgrade for non-MRC equipped SS models.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
06-28-2017, 09:11 PM | #22 | |
06-29-2017, 07:38 PM | #23 | |
06-29-2017, 08:28 PM | #24 |
So was I, but it makes sense when you figure in the stiffer rear swaybar the 1LE has over the SS.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
06-29-2017, 08:44 PM | #25 |
I wonder if the 1LE swaybar kit that's sold is a good idea then for SS cars? Might be too stiff in the rear.
06-29-2017, 10:00 PM | #26 | |
07-06-2017, 01:32 PM | #27 |
Good news/bad news....but its progress!
So i was able to find some part numbers...
Bad news....no prices.... Good news but the warehouses show stock of them... The springs arent listed yet nor are the camber plates.
07-06-2017, 01:48 PM | #28 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
Good job Polynesian. Info is slowly trickling in.
