Old 11-05-2016, 07:58 PM   #1345
warriordave927
Deadpool
warriordave927's Avatar
Drives: 2016 camaro lt rs m6 redhot
Thanks mgd,ill check them out
warriordave927 is offline   Reply With Quote
Old 11-05-2016, 08:07 PM   #1346
PinLover
PinLover's Avatar
Drives: 2017 2LT 50th, 2013 2LS
Originally Posted by John20162SS View Post
Thanks, they worked well
Can I ask where you got them? I am looking at a set from Harbor Freight, but can't judge if they are too steep for the front splitter. I just need them to do oil changes.
2017 50th Anniversary Edition 2LT V6 6-spd Manual - Order TQHKNZ
Received VIN 08/23/16: 1G1FC1RS2H0127445
Dennis Vaughan @ Schumacher Chevrolet in Lake Park, FL
1100 - 07/09/16 | 9000 - 07/22/16 - Order Cancelled from Stingray Chevrolet
1100 - 07/24/16 | 2000 - 08/02/16
3000 - 08/03/16 | 3100 - 08/08/16 - TPW 8/22/16
3300 - 08/10/16 | 3400 - 08/11/16
3800 - 08/23/16 | 4200 - 08/29/16
4800 - 09/03/16 | 5000 - 09/07/16
6000 - 09/10/16
2013 2LS Build Page: 2 THE CAVE... I'm Batman! 2LS Blackout
2013 2LT/RS Build Page: The Evolution of Iron Man
PinLover is offline   Reply With Quote
Old 11-05-2016, 08:10 PM   #1347
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Cheap and effective, 1 year old And going strong:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You May Drag the flaps A bit But I took mine off anyway.
Old 11-05-2016, 08:17 PM   #1348
PinLover
PinLover's Avatar
Thanks Glen. Just saw these RhinoRamps at K-Mart tonight for $49.99. I temporarily passed because HF has the Magnum 16000's for $39.99 and I think I can use the 20% off any one item coupon. I wanted to verify the min height to clear the splitter first before I bought them.
Also, after looking at a handful of reviews and pictures on Amazon, the RhinoRamps seem to collapse after 2-10 uses. I know you said you're a year in with them, but those pictures look dangerous. I'm sure the metal ones can bow and bend and be unsafe as well.
Why did you take off the flap (I assume you're referring to the piece that hangs lower than the splitter)? Isn't that there to protect the undercarriage from some dirt, as well as push air flow away from the undercarriage as well?
6000 - 09/10/16
Old 11-05-2016, 10:10 PM   #1349
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
race ramps 40 is an excellent all-around ramp. It's solid. it's super light. It's anti-slip. It has handles and it stands up nicely against the wall taking up a minimal amount of area.
But that's not why I posted. Take a look at these guys. Hydro-dipping FTW.
These are the first pieces i've ever done. I think they came out pretty good.
Just after rinse - no clear on yet.
Old 11-05-2016, 10:14 PM   #1350
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I hate the flaps, I don't like the way they look, Ive taken them off every car I've ever owned , I've never had any problems with airflow or dirt.
Old 11-05-2016, 10:24 PM   #1351
Rsblueblood
Kywildcats
Rsblueblood's Avatar
Drives: 2020 2SS shock and steel (shocker)
Looks great, what kit did you use?
Rsblueblood is offline   Reply With Quote
Old 11-05-2016, 10:25 PM   #1352
2slow95vert
Drives: 2016 2SS Hyper Blue
Looks great
Hey MGD, that looks great. Is the console lid more padded than original? I had a DSW lid in a '11 vette and it was more padded and comfortable.
Originally Posted by MGD View Post
Replaced my shift boot and console lid. Love it.
2slow95vert is offline   Reply With Quote
Old 11-05-2016, 10:32 PM   #1353
cellsafemode
dipmykit. However, they dont give you nearly enough primer and base coat and clear coat to deal with parts you need to wet-sand.
Luckily, those things can be purchased cheaply locally.
This is the Silver and clear CF pattern. Black base coat. It looks awesome in person.
Old 11-06-2016, 08:34 AM   #1354
John20162SS
John20162SS's Avatar
Drives: 2016 2SS
www.reverselogic.us
John20162SS is offline   Reply With Quote
Old 11-06-2016, 09:38 AM   #1355
2SSmurf
2SSmurf's Avatar
Drives: 2017 Camaro 2SS Hyper Blue Metallic
Ramps vs. Jack and Stands
Something to remember about changing oil on ramps is that you may not get all of the old oil out when your car is not level. I don't know much about drain pan design, so maybe it accommodates for a slight angle... but if you want to be sure, you should jack the car up level.
I use this jack: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
With the ZL1 jack pad + 6th gen magpuck: https://zl1addons.com/collections/ja...nt=27712440001
And 4 jackstands (No link because I've had them since I was a kid)
There's a pinchweld jack point about a foot or two from the front wheels, and then there's a good pinchweld jackstand location between the jack point and the front wheels, and also right in front of the rear wheels. The car is so stiff that you can jack each side only once. Just be careful when lowering the car onto the jack stands because the pinchwelds can bend (so I'm told - I haven't done it yet in the few times I've lifted the car)
...But most importantly, you can make you car do magic... O.o
2SSmurf is offline   Reply With Quote
Old 11-06-2016, 10:04 AM   #1356
vet757
vet757's Avatar
Drives: ^^^This
Got new wheels and washed this morning.
vet757 is offline   Reply With Quote
Old 11-06-2016, 11:51 AM   #1357
MGD
MGD's Avatar
Drives: 16 Camaro SS
Yep, it has a quarter inch padding sown in. Feels good.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 11-06-2016, 11:57 AM   #1358
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Drain bolt for the V-6 is at the rear corner of the pan, no problem using ramps.
