#13427 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
Maneuvering your transmission sounds difficult. Pretty heavy chunk of metal
2011 2SS/RS built 8/24/10
#13428 | |
Mother of PWA Babies
Drives: 2011 RJT 2LT/RS Join Date: Apr 2011
#13429 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Yeah a bit. It's annoying with window tint now being a primary offense but oh well. Going to try and remove it myself this time so that'll be fun. Gonna use a clothes steamer, been watching YouTube videos this afternoon. Certainly not paying whatever it'll cost to remove it. Just gotta be extremely careful on the rear window...
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#13430 | |
#13431 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
#13432 |
![]() Drives: 2017 Camaro 1SS M6 Join Date: Feb 2016
wouldnt that wear the synchros?
#13433 |
#13434 |
Young Blood
Not any faster than normal as long as you are still shifting in proper gear sequence. 1-2-3-4-5-6. "Perfect" rev matching will be the least stressful, but realistically perfect rev matching doesn't exist. If you skip sequence and go from say for example, 1-2-4, you will wear the synchronizers out faster. Same thing about perfect rev matching applies here as well. So no realistically as long as you maintain proper shift sequence speed shifting will not have any extra wear on the synchronizers.
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
#13435 |
on a bike you don't really do anything different, just leave the clutch out. I wish cars had wet clutches like bikes do
#13436 | |
Motorcycle transmissions don't have neutral between gears like a car transmission does, thus meaning no synchronizers. Motorcycle transmissions use "dog rings" which just require the release of tension, so the method on a motorcycle is accelerating-close throttle(which releases the "dog rings") shift-back to throttle.
Modifications
#13437 | |
#13438 |
Just makes for smoother shifts.
Modifications
#13439 |
i have a lot to learn
#13440 |
While I may not know everything, I know an extensive amount about a lot of things. Feel free to ask
Modifications
| Tags |
| i can haz a tag? |
