View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.97%
2017 57 34.13%
2018 77 46.11%
2019 3 1.80%
2020 4 2.40%
2021 1 0.60%
Voters: 167. You may not vote on this poll
Old 04-02-2023, 07:06 PM   #1303
Mark R
Drives: 2018 ZL-1
Originally Posted by gblaue View Post
One thing that I think gets lost in the weeds is that in 2019, GM changed the oil requirement from 5w30 to 0w40. How does that affect this issue? I change my 2017 over to 0w40. I haven’t had any issue, yet. I am having my pump changed out next week, but maybe GM may have made this change because of this.
I don't think that's the case. An oil pump should never break, regardless of oil. There should be a huge margin of strength built into the stock oil pump. Katech did it. It's not rocket science.
Old 04-02-2023, 07:44 PM   #1304
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
Katech changed to a forged steel, from a sintered steel. Big difference.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 04-03-2023, 12:59 AM   #1305
SammYyYyY
Drives: 2018 ZL1 1LE
Originally Posted by george View Post
Did the dealer say if the oil pump was damaged?
They didn't specifically tell me if/how it was damaged, but my idle pressures have returned to a steady 30 PSI now that it has been replaced, so I think it's safe to conclude that it was starting to fail.
SammYyYyY is offline   Reply With Quote
Old 04-03-2023, 10:44 AM   #1306
Tyrolblue67
Drives: 2019 ZL1 Camaro
Sammy,
Can you share the part number of the oil pump they used as a replacement?
Thanks,
Tyrolblue67
Tyrolblue67 is offline   Reply With Quote
Old 04-03-2023, 03:03 PM   #1307
SammYyYyY
Originally Posted by Tyrolblue67 View Post
Sammy,
Thanks,
Tyrolblue67
12686434
Old 04-03-2023, 05:10 PM   #1308
Tyrolblue67
12686434
Thanks 👍
Tyrolblue67
Old 06-23-2023, 02:53 PM   #1309
camaro99
camaro99's Avatar
Drives: Angry Dorothy II 2016 2SS
2018 zl1 engine power reduced code??
Well it looks like I have same oil pump failure issue.
My canadian dealer said to try putting a oem ac delco oil filter.
since I put in a fram type last month and thought it odd ti happen at only 7500 miles ..12000 km.
Also have humming noise which may be faulty drive shaft bearing ?
Anyone have that issue too on 2018 zl1?
camaro99 is offline   Reply With Quote
Old 06-26-2023, 02:42 AM   #1310
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
It sucks for all of you that have had issues with the oil pump, no doubt. But sh!t happens. Manufacturers (of anything) never have perfect quality. They can't just go replace all the oil pumps or it would break them. Again, it's a damn shame it happens. But if it happens to me, I'm not worried about it. I'll fix it and move on. If it bothers you all that much, sell the car and get something else.
Hi RobZL1, I also have a 2017 ZL1. How many miles do you have on your car? Are you doing anything for the oil pump to keep it strong, such as oil changes? I’m keeping an eye on the oil pressure but switched to 0w/40 as well as warming up the engine before driving. I did some calculations on these numbers and it seems 17% of all 2017 ZL1s have had a failed pump, based on total production of 3048 ZL1s in 2017. There is a total of 51 2017s in this forum reporting a failure. Which means, the number is probably higher since not all 2017 owners are likely here. That is a significant number of failures.
george is offline   Reply With Quote
Old 06-26-2023, 02:57 AM   #1311
george
ZL1 Driver
george's Avatar
I would take the car in for service and diagnose the problems. There is a TSB on the oil pump.
Old 06-26-2023, 10:07 AM   #1312
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
A little over 15k miles. I do nothing special- just change the oil when the computer tells me to change it. I use 5w30 Redline, personally. I don't warm up the engine before driving. I let it idle for about 60 seconds, then back it out of the driveway and go. I keep light throttle until the oil temp is 175+. Otherwise, I just keep an eye on the oil pressure at idle. If it ever drops below 30psi, then I'll park it and order a cam kit and oil pump.
Not sure how you can accurately extrapolate to get 17% failure of all 2017 ZL1's, but I know it's probably not a small number. If you look at the facebook group, you'd think it was every 2017 and 2018 ZL1.
Mods being installed-
Old 06-26-2023, 10:13 AM   #1313
Z OH 6
Drives: 2021 Red Hot ZL1
Its certainly a very significant percentage. Just be thankful yours hasn't failed yet as long your dealer is willing to replace it when it does fail.
Old 06-26-2023, 11:06 AM   #1314
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
No dealer touches my car. If it fails, it will get a Katech along with a cam kit. If it doesn't fail, it will get replaced when I do the cam which is about 2 years out.
Old 06-26-2023, 01:56 PM   #1315
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Your dealer is a moron. Oil filter has nothing to do with it
ZX-10R is offline   Reply With Quote
Old 06-27-2023, 10:40 PM   #1316
Nitronut
Nitronut's Avatar
Drives: Duramax, 2018 Camaro SS 1LE
Technically, a heaver WT oil would put more strain on the pump.
If it ain't buckin, chirpin & makin all kinds of bad noises.... then I ain't happy!
Nitronut is offline   Reply With Quote
