#12867 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Wonder if Blackstone would be able to tell if my cam was going bad because of this lifter tap. Giving it a shot but I did drain out about 3/4 of a quart and it's noticeably quieter. Confused? Yes.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#12868 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 Red Hot 2SS/RS A6 Camaro Join Date: Oct 2013
I'm feeling better about everything. Thanks for all the encouragement. Y'all are the best
Current Camaro: 2014 2SS
Performance Mods: BBK Headers, Borla S type axle back, tune, TSP Stage 1 cam, Vararam Intake, DR's 11.77 @ 119.21 Former Camaro: 2013 2LS BONE STOCK: 13.953@100.77 With Bolt-Ons: 13.646@101.60 With 75 shot and Bolt-Ons: 12.587@111.25 Performance Mods: CAI Intake, MRT V2, SLP Underdrive Pulley, DRs, Skinnies, Rear seat delete |
#12869 |
![]() Drives: 2017 Camaro 1SS M6 Join Date: Feb 2016
anyone ever used chemical guys or any other similar cleaning brand? been very OCD with my cleanliness. plus does polishing/waxing remove those faint scratches?
#12870 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
CG blows. Adams is my favorite for most stuff. Compound=deep scratches Polish=light scratches Wax=filler/protectant. Cleaner wax has some light abrasive properties.
2011 2SS/RS built 8/24/10
#12871 | |
Or get Meguiars Gold Class as its widely available pretty much everywhere that sells anything car related and its a really really good car wash.
2010 2SS/RS
#12872 |
Tri-County Camaro SWFL
+1 for Adams. Customer service is top notch
#12873 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Adams and Menzerna are top on my list for products I use and satisfied with
#12874 |
ok will give adams a try out. do you guys recommend any kits/individual items together? looking for a good clean and polish/waxing
#12875 |
meguiars clay, DA compound, polish, and wax! Lot of work but worth it in the end!
#12876 | |
AKA "Beefcake"
See, you are just opening up for a lot of questions, based on your needs. It's best to start with the essentials, and work your way to the "nice to have" stuff. |
#12877 | ||
I like Meguiars 101 and 102 for compound and polish, then I have a few waxes/sealants from Meguiars, Detailers Pro, Duragloss, Surf City Garage and a few others. The ones I usually go to are Megs #26 wax and Duragloss 111. Good combo and seems to last a few months. Since we get a ton of pollen I like to use Finish Kare #425 spray detailer as it really helps keep pollen off my car. Check out the detailing section on here. Tons of info, but I would not jump into compounds or polishes just yet. Stick to getting the wash down perfectly (as in avoid adding scratches and or swirls to the paint) and get some good wax and or sealant along with a clay bar kit.
2010 2SS/RS
#12878 | |
@justjoshin and xc_SS/RS they do sound like a alot of work but thats fine because a lot of work results in a detailed clean. will check out the websites and options available. thanks for the feedback guys |
#12879 |
COYG
Drives: 2010 RS Bumblebee Join Date: Jul 2015
One more midterm to go...
#12880 |
I did this polishing by hand. Look at the recommended product list in the detail section
| Tags |
| i can haz a tag? |
