View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.97%
2017 57 34.13%
2018 77 46.11%
2019 3 1.80%
2020 4 2.40%
2021 1 0.60%
Voters: 167. You may not vote on this poll
Old 01-30-2023, 12:46 PM   #1261
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
All seem to be failing in the same spot where that little cutout for pin is located. Hard to believe even the replacement failed! In any other universe this would be a recall but GM would go broke. This doesn't seem to happen as frequently with the SS Camaro right?
ZX-10R is offline   Reply With Quote
Old 01-30-2023, 01:53 PM   #1262
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
Originally Posted by Vtor_ZL1 View Post
Pump on work order from 9/30/2020 is Part No. 12686434, description reads Pump 1.652
Which I believe is still the current pump!! So I get another one.. thanks GM - heart is warm w joy.
lol i bet, this is the "revised" PN pump i picked up...damnit
jvandy50 is offline   Reply With Quote
Old 01-30-2023, 02:00 PM   #1263
Mark R
Drives: 2018 ZL-1
It's hard to believe this continues year after year. That cutout is simply a crack waiting to happen. If they had machined a bulge into that ring, and a cut-out in the case where the pin goes, the ring would have rotated on its strongest point, not the weakest point.
Old 01-30-2023, 03:15 PM   #1264
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I'm sure it passed 100k mile, stringent durability testing, with a pretty harsh engine loading schedule. I'm sure it passed everything they threw at it. Just something different going on here. Maybe the additional snout load from the supercharger belt or something- who knows. But, heck, they still would have tested the LT4 engine on the same durability program.
I'm just going to enjoy my 2017, and if the oil pressure drops before I plan to do a cam, then I'll just do the cam earlier than planned.
Mods being installed-
RobZL1 is online now   Reply With Quote
Old 01-30-2023, 03:34 PM   #1265
ZX-10R
ZX-10R's Avatar
More likely it was all computer simulated stress analysis with some limited real world testing. It's a fatigue failure at a thin spot in the pump housing, there is no mystery or "something different going on" - failures are random with no connection to viscosity. Hard throttle before oil has reached temp (at least 180 F) could be a contributor
Good ol GM
Old 01-30-2023, 03:44 PM   #1266
Mark R
Drives: 2018 ZL-1
Good ol GM
An oil pump should not be on the verge of failure such that cold oil makes it break. This is a total fail by GM.
Old 01-30-2023, 04:34 PM   #1267
Katech_Mike
Drives: 2015 Camaro ZL1
Originally Posted by taylorforschool@gmail.com View Post
I think it would be interesting if Katech would tell us in terms of power of their part is 2x or 3x or maybe 1.5x stronger than the updated OEM. Idk if it’s that’s simple, but I’d be curious to know just HOW MUCH stronger the katech is over the revised oil pump from GM. Maybe see all 3 pumps compared on a scale as supposedly the revision is confirmed to be stronger
Our pump internals are made of 4140 steel where as the factory is some type of cast or potted metal.
I can throw the OEM vane housing on a concrete floor and it cracks in half.
I can put ours in a vice and beat it as hard as I can with a mini sledge hammer and it won't break.
Katech_Mike is offline   Reply With Quote
Old 01-30-2023, 09:02 PM   #1268
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Good ol GM
Well, then I stand corrected. They certainly used to do actual fatigue testing, at both component level at the supplier and assembly level at GM. But it's been decades since I was in that business. I'd think they would have caught infantile failures in some level of stress testing, though. I used to have to beat the crap out of parts.
Regardless, there are too few failures for any other approach from GM's perspective. Repair the ones that fail under warranty, and that's that.
Old 01-31-2023, 10:56 AM   #1269
Boost or bust
Drives: 2018 ZL1 M6
Hey, gang. Surprised nobody has initiated a class action suit against GM, since they know about this problem. Safety issue? Heck yes…just saying. Any lawyers out there? Can we strong arm GM into doing the right thing?
Boost or bust is offline   Reply With Quote
Old 01-31-2023, 11:12 AM   #1270
Z OH 6
Drives: 2021 Red Hot ZL1
LOL.
Old 01-31-2023, 02:50 PM   #1271
Vigilante375
Drives: 2018 Camaro ZL1
Just like the lawsuit that never happened for the 04 GTO where the plastic engine cover would cut into the thin rubber fuel line and cause the car to catch fire?
GM "fixed" it by adding a thicker piece of rubber on the area that get cut in the 05/06 GTO.
Even then, the lawsuit would only go towards the affected vehicles that have prove it failed. The ZL1 lawsuit I mean.
Old 01-31-2023, 04:15 PM   #1272
Mark R
Drives: 2018 ZL-1
You can't sue for damages that have not happened. So far, GM is fixing all that are breaking, per the experience of owners on this forum. That seems to be their strategy. Fix what breaks and run out the clock.
Old 01-31-2023, 04:37 PM   #1273
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Run out the clock is the bit that troubles me and i'm guessing most owners holding the title!
ing for grip.
http://www.motorsportsne.com/
Old 01-31-2023, 04:45 PM   #1274
Stevezx900
Stevezx900's Avatar
Drives: Buick Grand National, BMW M5
10 year 100k engine warranty sounds good to me.
Oil pump only will work.
Stevezx900 is offline   Reply With Quote
