Old 02-19-2014, 03:46 PM   #1261
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Originally Posted by menendez1293 View Post
With a standard installation of 8.1 with a recovery and driver partition you get about 465gb of a 500gb for file storage.
A 500 gig commercial hard drive (which contains 499,289,948,160 bytes) is actually 465 gigs (499,289,948,160 / 1,073,741,824) before being formatted and before anything is installed (I looked it up). Windows 8 requires 20 gigs and it uses another 18 gigs for various programs it installs taking up a total of 38 gigs. This means a 500 gig commercial hard drive after having just the OS and no other programs installed will have 427 gigs left over for the user.
Mr_Draco is offline   Reply With Quote
Old 02-19-2014, 05:02 PM   #1262
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Originally Posted by PoorMansCamaro View Post
just read that it takes 90 minutes to drive coast to coast in "The Crew". lol
Well that's Kissimmee to Tampa at 3:00 in the morning.
2023 GMC Canyon Elevation
Old 02-19-2014, 07:03 PM   #1263
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Sorry you are correct about the size of a disk being smaller. I forgot about the whole convert to 1024, I was thinking of a disk space in terms of humans and not computers. But as for the install I have successfully installed windows 8 and 8.1 in a Hyper-V machine hosted in a Windows 8.1 Box with 25Gbs of allocated space. This not only installed the base image but also office 13, several other desktop apps, and several RDBMS clients along with their files.
Here is a fresh install of Windows 8 on a 320Gb drive I just did on a older laptop of mine. This is just the install of a base 8 with all apps installed and an install of iTunes. As you can see the OS is only using 14Gb of the boot volume and 500Mb recovery in the other partition
Old 02-21-2014, 11:16 AM   #1264
truth411
Drives: 2022 SS 1LE
xbox has said they will have external hard drive capability in the future.
also, it's said that xbox can hold up to 7 dual layer blue ray games and 14 single layer. PS holds up to 8 and 16, respectively. So it's really not that big of a difference.
Good luck with that, no telling when that will happen. Also M.S. not making the internal HDD non upgradeable is pretty telling. Also aren't external hdd slower than internal ones? Anywho I'll probably pick one up when Gears of war eventually comes out.
truth411 is offline   Reply With Quote
Old 02-21-2014, 12:39 PM   #1265
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
No, internal and external HDDs are the same. However going over USB 2.0 would be a hindrance versus internal SATA. The XB1 is equipped with USB 3.0 ports which have enough bandwidth that you wouldn't know the difference in terms of read and write speeds.
If you've been following the XB1 before and after its launch you would know Microsoft is actually receptive to criticism and willing to give the fans what they want. Major Nelson confirmed external HDD support will be supported later down the road.
SPARTAN sui is offline   Reply With Quote
Old 02-21-2014, 06:08 PM   #1266
truth411
Drives: 2022 SS 1LE
Thanks for the info, but I have to imagine that even usb 3.0 would be slower than internal Sata connections, but I could be wrong.
Old 02-21-2014, 06:26 PM   #1267
menendez1293
Isn't 3.0 a 5Gb/s connection on paper while the Sata is a 6Gb/s connection on paper?
I am assuming the One is a 6Gb/s connection internally as I haven't really read into the tech specs of it.
Old 02-21-2014, 06:52 PM   #1268
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Something else that's crazy, I was checking out how much games would be for a kid, and angry birds Star Wars is like 50 or 60 dollars!!! Wtf?! And then zoo tycoon is also 50 or 60. That is just nuts.
Old 02-22-2014, 08:11 AM   #1269
menendez1293
Wow I can't believe they charge 50 bucks for Angry Birds: Star Wars. I think the most I would pay is like 10 for it.
Old 02-22-2014, 11:58 AM   #1270
SPARTAN sui
PC Technician
Yep, on paper SATA is faster. However those bandwidth speeds have far surpassed the maximum bandwidth speeds that a hard disk drive can perform. In real world tests the faster HDDs can read and write around 100MB/s, or .8Gb/s. SSD are another story, they're typically 5x faster at this point, 500MB/s or about 4Gb/s.
As you can see mechanical drives simply aren't quick enough to utilize all that bandwidth. They probably won't ever be. SSD's are a different story.
Old 02-23-2014, 11:35 AM   #1271
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
Several months behind but I finally opened and played my XbOne with BF4. Played it for about 30 mins. The graphics are amazing. Hopefully I can get to play on live this week
LIM3 is offline   Reply With Quote
Old 02-23-2014, 09:39 PM   #1272
menendez1293
Anyone else having Netflix issues? This morning I had no issues at all with Netflix but now it just buffers every 5 minuets. Got so bad I had to boot up the 360 and it hasn't buffered once in the middle of the show. Did the sand thing yesterday as well.
Old 02-23-2014, 10:02 PM   #1273
SPARTAN sui
PC Technician
Are both your 360 and XB1 connected the same way? Wireless or wired?
Netflix streaming seems to be working good for me. I've been watching a few different things today.
Old 02-23-2014, 10:24 PM   #1274
menendez1293
XBoxOne Discussion - New XBox Console
Xbox one is wired 360 is wireless. Even if I put the One wireless so it's the same setup at the 360 it still buffers. Have a friend that has the same issue who has the One on a wired connection. My MacBook, iPad, 360 and Blu-Ray player all work without a problem only the One buffers.
It was working fine for me all day long but at night time I just get buffering. The same thing happened yesterday as well
