#113 | |
Moderator
Rail commanded/actual pressures Injector pulse width Ted may have some more thoughts but that’s the TLDR version.
#114 | |
I thought high-pressure fuel pump delivery duration was a key PID.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#115 | |
Moderator
High pressure fuel pump pressure IS rail pressure…the HPFP is what charges the two fuel rails that feed your injectors. If that pressure drops off then your IPW will jump up… no bueno. Keep your IPW under 6.0 in my opinion.
#116 | |
#117 | |
IPW <6.0ms Rail pressure no more than 2-300psi lower than commanded. HPFP delivery angle < 130 degrees EOI >150
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 08-10-2024 at 06:29 PM. |
#118 | |
2020 ZL1LE A10.
#119 |
Moderator
Totally fine
#120 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
This
GM Gen V Calibrator
#121 |
Petro-sexual
Thanks for the feedback! Just trying to verify
#122 |
![]() Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
How Would You Get to Full E With the Streetbrawler Package
I thought this was an interesting exchange. I love the concept of your 580rwhp Streetbrawler package. What would you add to that package to get to full E?
#123 |
Snackbar Tuning
So far the ceiling seems to be ever so slightly higher than the LPE BB pump when on the stock LT4 cam lobe. I know the Goliath really shines with a cam but it will get you to E60 on a full bolt on, XDI 30's, X port and 2.3 upper setup. You can push past E60 but the rail pressure start to fall off. If you dropped the boost down it would probably support E80. I'm hitting 14.3 psi in 88F/2300 DA weather.
GM Gen V Calibrator
#124 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#125 | |
Petro-sexual
![]() THIS. Not that I would go to strictly DI, because of my situation, but if I ever decide that's something I need to do, it's good to have this information.
#126 | |
