Old 05-18-2022, 12:49 PM   #113
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by ZL1Atlanta View Post
I can drain and circulate from the trunk but it runs all the time with the ignition on.
Who did you buy your tank/system from?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 05-18-2022, 12:54 PM   #114
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
It is a custom tank from Vengeance available for in house builds.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 12-26-2022, 07:14 PM   #115
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
I did and spacers.
Sorry, did you need to change your belt with a longer one when adding the spacers?
Thank you.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
Old 12-26-2022, 07:26 PM   #116
JSH
JSH's Avatar
Drives: '20 ZLE
Thank you.
A 1/4" change in pulley diameter requires a new belt, so, yea.
2020 ZL1LE A10.
Old 03-02-2023, 03:48 AM   #117
Akura
Akura's Avatar
Hello,
Just installing my FI Interchiller, but have a problem with the coil line: the hoses and clips that FI sent are too small (8mm) or too big (16mm) for this fitting (12mm), pics attached. The others fitting were OK, but this line doesn't.
Did you have the same issue? If I buy a 12-13mm hose myself and install it in this line, performance of the chiller won't be decreased isn't it?
Kirk is not answering my mail about this problem, that's why I write the post.
Thank you.
Old 03-02-2023, 01:14 PM   #118
ramairroughneck
Drives: 2018 Camaro SS
The greatest restriction is the size of that fitting. Might as well use the smaller hose. A larger hose won’t allow it to flow more
ramairroughneck is offline   Reply With Quote
Old 03-02-2023, 02:11 PM   #119
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Hello,
Thank you.
No didn’t have that issue, but something doesn’t look right. I can’t remember the hose sizes off the top of my head and CSP installed it but I would try reaching FI on phone. They always respond.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 03-02-2023, 02:29 PM   #120
Akura
Akura's Avatar
Thank you both, finally Kirk answered the mail and yes, they sent an incorrect size hose (bigger, I suppose would fit another car). They will send me ASAP the correct one, but I will try to find one by myself and the one who arrives the first will be installed.
Thank you again
Old 03-04-2023, 10:54 PM   #121
airtroop01
Drives: 2018 Cadillac CTS-V
Cool thread…
@camaro1973 - Thanks for the data points and the tip about wrapping the lines. I’ve only got the Stage 1 kit w/ a fender tank and see about 13*F above ambient in cruise conditions. Still better than 140*F temps I was seeing before on the street.
You see all these vids with frosty lines and start wondering WTF - I want frosty too. I plan to open track with this setup, however. I’ve installed a switch-activated bypass with Kirk’s help. My thought is that I can super cool things in the pits and switch the bypass on so the HE setup keeps the temps from getting too out of control. I had attempted to do this automatically via a temp probe - and still may - but it was much simpler to install a switch for the time being. I also just got a Pierburg pump to put in over the stock setup and hopefully that helps things out further. If I can keep the temps from getting too out of control for 20min, I’ll consider that a victory.
airtroop01 is offline   Reply With Quote
